Bent Cradle. Worth repair?
Old Jul 5, 2012 | 08:45 PM
LSfan70s's Avatar
LSfan70s
8th Gear
Default Bent Cradle. Worth repair?
I got a C5 full front suspension from the junk yard with a bent right upper control arm for a project. I thought the only damage was the control arm, but when I went to bolt the 2 C5 pieces of front rails I had, I noticed the right rail was about 1.5 inches higher at the front tip, where it was welded to the chassis front bumper/cross member.
Does it worth to try to repair the cradle? Or should I better get another one?
Any suggestion is highly appreciated.
Old Jul 5, 2012 | 10:14 PM
robert miller's Avatar
robert miller
Get a diff one man. THERE WAS ABOUT 2 ARE SO IN HERE FOR SALE NOT LONG AGO... Do a search you will find one.. Good luck with the build. Robert
Old Jul 6, 2012 | 07:02 AM
WKMCD's Avatar
WKMCD
FWIW: ECS also has a custom cradle for laying down the radiator if you want to.
Old Jul 6, 2012 | 10:16 AM
jfernandez98's Avatar
jfernandez98
I belive Vettenuts has them New
Old Jul 6, 2012 | 11:00 AM
I would get one that is totally correct. I'd see if the salvage yard would take it back and then look for a better one.
Old Jul 6, 2012 | 11:18 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Are you referring to the aluminum engine/suspension cradle? We have them in stock for $85 plus shipping. We also have the lower radiator support/skid plate in stock as well.
To Bent Cradle. Worth repair?
