Hello everyone, I was wondering if anyone knew if the C-5 coupe uses the same mount bracket for the waterfalls between the seats as the C-5 convertible? I have a Coupe and was able to locate the part online for the convertible but was wondering if they both use the same part number. Thanks for your help in advance!
The convertible's waterfall is actually an enclosure for the latching mechanism for the tonneau cover. There wasn't an OEM one for the other two models (coupe, FRC), but as mentioned, someone else has made them for those applications.
