[Z06] DRL Light Leak fix.
Old Jul 9, 2012 | 02:08 PM
DARRYLZO6's Avatar
DARRYLZO6
Default DRL Light Leak fix.
Just to keep this short, my DRLs blow almost always after I wash the Z. Ive read about some fix at the top of the housing to prevent leaks. Can anyone tell/show/illustrate the best way to do this. Thanks..
Old Jul 9, 2012 | 03:55 PM
bumble-z's Avatar
bumble-z
Good luck.
Old Jul 9, 2012 | 04:18 PM
FourG63 97GST's Avatar
FourG63 97GST
basically, the heat from the bulb in the lens, melts the plastic just above it.
now a Fix? LEDs bulbs maybe, or just replace the housing.
Old Jul 9, 2012 | 06:43 PM
MikeD33's Avatar
MikeD33
I always just turn mine off when I wash it and wait till the next day to turn them back on.
Old Jul 10, 2012 | 11:54 AM
pluslt's Avatar
pluslt
You can buy a new set for under $100. Once that plastic has melted its a lost cause. I swapped mine out last year for aesthetic reasons and its not all that difficult. I gave away my stock housings in last year's X-Mas pay it forward thread. If you post up asking for a used set someone might just give them to you. I think the aftermarket ones look much better and I'm sure more than one person has a stock set sitting around collecting dust.
GL.
Old Jul 11, 2012 | 02:21 PM
joopblog's Avatar
joopblog
what is a drl?
Old Jul 11, 2012 | 03:29 PM
vant's Avatar
vant
Originally Posted by joopblog
what is a drl?
Daytime running light. Also known as a corner light or bumper light.
Old Jul 11, 2012 | 03:32 PM
vant's Avatar
vant
I agree. Replace the housing and install LED bulbs. They'll run much cooler and shouldn't melt the plastic like a regular bulb might.
Old Jul 11, 2012 | 03:48 PM
bumble-z's Avatar
bumble-z
Do you need to add anything else. ?
I thought you had to add something else in the line if changing over to the LED's, otherwise the blinkers would blink rapidly???
Old Jul 11, 2012 | 04:24 PM
vant's Avatar
vant
Yes. I believe you need a special wire harness for the LED bulbs. Since an LED uses much less power than a regular bulb, the computer thinks that the bulb has burned out and it does the rapid blinking thing. At least that's my understanding.
To DRL Light Leak fix.
