C5 dash removal
Jul 11, 2012 | 09:30 PM
C5 dash removal
Does anyone out there know the steps for removing the dash out of an 04 Z06. Any help is appreciated.
Al
Jul 11, 2012 | 09:53 PM
Do a search for adding a HUD....covers the dash pad removal in detail.
Jul 11, 2012 | 10:08 PM
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Believe or not it starts with removing the entire console from the back to the front before you can remove the radio bezel which also has to come out. Not as big a job as it might sound but it does take time.
Contact JW Motoring, Jhonathan will help you out for sure!
Also search is your friend!
Jul 11, 2012 | 10:16 PM
This is a step by step removal of the console. It is for a shifter replacement but it details exactly how to remove the consone piece and you can disregard the rest...
http://www.corvettefever.com/techart...l/viewall.html
Jul 11, 2012 | 10:20 PM
Jul 11, 2012 | 11:22 PM
Jul 12, 2012 | 01:23 AM
Dec 6, 2012 | 07:47 AM
Awesome video
Quote:
Originally Posted by
Zr-1Mike00
Thanks. This is a fool - proof instruction.
Dave
Dec 6, 2012 | 09:39 AM
Armed with the above info, you should be able to get the dash apart. What project do you have in mind?
Dec 6, 2012 | 11:46 AM
It's way easier than you think !! I've done it about 4 times.
Dec 7, 2012 | 05:04 PM
Gas door switch plug was
a bit of a challenge on the console reinstall. They should have added about 6" of wire, but that would cost them and be too easy.
If you have a vert the waterfall comes off with only four screws.
