Memory Functions
Old Jul 14, 2012 | 03:56 PM
lms1943's Avatar
lms1943
Cruising
Default Memory Functions
A new to me 2004 C5 (with only 7800 miles), and I have a memory problem with the seats/steering. I can set it and it will work a few times then I have to reset it. I installed a new Optima battery and I have checked the starting voltage and all acceptable.
IdeaS AND OR SUGGESTIONS
tHANK yOU
Old Jul 14, 2012 | 05:27 PM
aminnich's Avatar
aminnich
You do know you have to press the unlock on the key fob first, right?
Old Jul 14, 2012 | 06:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Does the DIC return to the odometer display each time you start that it has a memory loss too? Leave the DIC on some other display. It should remain there the next time you start it up. If it goes back to the Odometer, usually a low battery. Note that not all Optima's are good and from the things I read in here, seems like %50 are defective but don't hold me to it. Check your battery cable connections at the battery and the starter solenoid.
Old Jul 14, 2012 | 08:23 PM
Big Duk's Avatar
Big Duk
Optima's are great batteries! Use your key fob so it can select memory #.
Old Aug 22, 2012 | 08:48 PM
driver68's Avatar
driver68
OK, so I just purchased a C5 also, and have a question on the memory/key fob.
When pressing the unlock on the key fob, how do differentiate between memory #1 and #2 settings?
Mine seems to be set to #2 when I unlock, and I want it to #1.
Gary
Old Aug 22, 2012 | 10:52 PM
red89c4's Avatar
red89c4
if you use the #2 key fob then the car will default to the #2 memory, if you use the #1 key fob it will default to the #1 memory
Old Aug 22, 2012 | 10:53 PM
02koolC5's Avatar
02koolC5
Gary
Look on the back it should have numbers on it
Old Aug 22, 2012 | 11:02 PM
Old Aug 23, 2012 | 12:12 AM
driver68's Avatar
driver68
Thanks guys.
Sure seems like a really stupid question now
Old Aug 23, 2012 | 09:59 AM
pmurray's Avatar
pmurray
Driver68,
Thanks for the "stupid" question because I did not know this either.:bb
Old Aug 23, 2012 | 10:33 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by pmurray
Driver68,
me too....and I've had this car 15 years!
Alex41's Avatar
Alex41
Holy face palm batman. I didn't know either and just realized I had key fob 2 on my chain. I just thought I had screwy problems. Thank god for the question OP.
Old Aug 23, 2012 | 11:57 AM
Ona mission's Avatar
Ona mission
St. Jude Donor '14
Me three... Great question and answers. I thought that I had an intermitent problem, some times it worked perfect, some times not at all. Had the #2 fob and it defaulted to that setting.
I also don't always lock the car, so I don't use the unlock function
One other thing that I got out of the manual Pushing memory function button doesn't work while you are moving, only stopped, Safety first
To Memory Functions
