[Z06] Drive line slop
Old Jul 16, 2012 | 10:34 PM
1BACORVETTE's Avatar
1BACORVETTE
Default Drive line slop
This being my first Vett, but by no means not my first stick, I have a question regarding the differential. During standard city driving and shifting up through the gears, 2, 3, 4th and back down, I notice a little slop between the transmission and the rear end. At least that's what it sounds and feels like. It's not really that bad, I can even shift and clutch so it doest happen. However it's still there. Is that normal or is there possible universal joint issues. I can't imagine a problem with universal joints, because I pulled a few hole shots and speed shifts with no problem at all. It all happens when you are being a lazy shifter and don't pay attention to how you clutch. Has anyone else experienced the same thing.
Old Jul 17, 2012 | 10:55 AM
1powdercoater's Avatar
1powdercoater
Default u joints
No u joints
Old Jul 17, 2012 | 11:40 AM
KillSwitchNY's Avatar
KillSwitchNY
Maybe the tranny mount?
Old Jul 17, 2012 | 01:59 PM
1BACORVETTE
I guess I'm not really that familiar with my own car. At least the underside. I still have never had a chance to take a look while it's up on a hoist. If I had I probably wouldn't have asked the above question realizing the configuration of the transmission. I now wonder if it is just common in the wheel/axil to rear end set up to have a certain amount of play. Thanks for pointing out my misunderstanding....
Old Jul 17, 2012 | 02:14 PM
KillSwitchNY
Yeah, I'm not a pro at the Y body yet either so I hear you. I am more of a conventional Motor, tranny, rear guy. LOL, the tranny in the back will get you every time. Definitely get under the car and poke around next time it's on a lift.
To Drive line slop
