Engine light on;Airbox!
Old Jul 19, 2012 | 06:00 AM
BigKitty's Avatar
BigKitty
Default Engine light on;Airbox!
The engine light is on in my 2001 Z06.A local garage checked the code and it said air box.He cleared the code .but it came ome twenty miles later.Is this a common problen for this car and what is the cost to fix?
Old Jul 19, 2012 | 07:06 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Simple fix -
Check all around the airbox and all the fittings to make sure they are sealed and tight and no extra un-metered air is getting 'AFTER' the MAF!
Did you change the airfilter or do anything to the Vette recently?
Can you pull the code for us?
What was the EXACT code?
Can you pull it and give it to us? please!
Thanks,Matt
Old Jul 19, 2012 | 07:33 AM
runner140*'s Avatar
runner140*
Originally Posted by madmatt9471
Simple fix -
Thanks,Matt
Or another question....do you want instructions on how to pull your codes.
Old Jul 19, 2012 | 08:19 AM
killain's Avatar
killain
Oldtimer
Default Check engine light ?
Simple fix -
Thanks,Matt
I'd put in a fresh air filter, simple fix, or if the light stays on I'd use compressed air nozzle and blow out any contaminates from in front of the radiator / evaporator, and or the worse is one of the oxygen sensors is bad. But if you pull the codes it should tell you what is the problem.
Old Jul 19, 2012 | 03:45 PM
soggysailor's Avatar
soggysailor
Also while you have things opened up clean your MAF. You can get an aerosol can of cleaner specifically for this at most automotive stores.
Old Jul 19, 2012 | 04:31 PM
BigKitty's Avatar
BigKitty
The car is a Garage Queen.I put 500 miles a year on the car.Covered up 24/7.No mice in my garage as I am an exterminator.Original owner.I will check the air filter and replace if necessary.
Old Jul 19, 2012 | 04:47 PM
BigKitty's Avatar
BigKitty
Air filter removed,will replace tomorrow.Can't it is a problem with only 10,000 on car.
Old Jul 19, 2012 | 05:18 PM
BigKitty's Avatar
BigKitty
I do not know how to pull codes!I thought that you needed a handheld device to do that!
Old Jul 19, 2012 | 05:36 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
and
http://www.corvetteweb.com/c5codes.html
Old Jul 19, 2012 | 05:48 PM
DARRYLZO6's Avatar
DARRYLZO6
Check the band clamps (if applicable) and make sure they are tight. Also if you are using the stock air box setup and youre using a aftermarket (screenless) MAF, you'll HAVE to get a Haltech Honeycomb screen for about $40 OR another maf with a screen. And YES.....I know that the maf in the 2001 ZO6 had a screen. When I removed my maf screen from my 2001 ZO6, I also got codes. Went back to the screened maf, solved the problem.
Old Jul 19, 2012 | 05:53 PM
killain's Avatar
killain
Oldtimer
Default Air box Leak?
I left out an important item, I swapped out my 2003 LS1 air box with a 2003 ZO6 air box, but the Little metal clamps that GM provides are trash, they couldn't hold a 2 LB baby from pushing the air box & lid apart. (I used two long about 18" snap cable ties and tightened down the air box lid with them, but since I was in there, I put a K&N high flow air filter in. It's good for 50.000 miles, and I think I've only got about 40K myself. Try the long cable ties and just snip off the extra piece. Good luck, simple fix, takes 10 minutes.
Old Jul 19, 2012 | 07:07 PM
BigKitty's Avatar
BigKitty
Thanks guys! BK.....I love my little 2001 Z,not like the 2008 Z that I own,The 2001 is a lot easier to drive.Not as demanding!
To Engine light on;Airbox!
