What's next??
Old Jul 19, 2012 | 07:07 PM
brickhammer's Avatar
brickhammer
Default What's next??
Just bought an 03 Z06 about a month ago. Put the column lock bypass on it and now it's getting the valve springs, plugs and new wires put on.
The car only has 8000 miles on it. Should I be checking the harmonic balancer or is that ok for awhile?
Going to Carlisle and will be putting around a 1000 miles on it that week.The car mostly sat for 10 years, what else should I be checking or changing? Tires look ok but their original, can't afford new ones just yet.
Tim
Old Jul 19, 2012 | 07:20 PM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
If tyres are original they are well by their recommended life and have the flexibility of wood. Would definitely recommend you replace.
Old Jul 19, 2012 | 07:45 PM
GrandSportRob's Avatar
GrandSportRob
since your going to Carlisle(as am I..) you should get an aftermarket exhaust..If you buy it there they put it on for free..I did it 2 yrs ago..(Corsa pace car)...Cost me about $1200(on a credit card)..Check out which brand you like since they're all there doing the installation..
Old Jul 19, 2012 | 08:12 PM
brickhammer
Not really looking to change from stock. Just trying to get the car reliable. Trying to replace the important things that might leave me stranded.
Old Jul 19, 2012 | 08:52 PM
I would replace the tires, and if you don't know when all the fluids were changed last, change all of them. Just make sure there are no leaks anywhere on the car and have fun on your trip.
Old Jul 19, 2012 | 09:06 PM
m6 c5's Avatar
m6 c5
I would drive it more....
Old Jul 19, 2012 | 09:15 PM
brickhammer
Plan on driven it. Can you buy tires at Carlisle?
Old Jul 20, 2012 | 06:11 PM
brickhammer
Any input about the harmonic balancer?
Old Jul 20, 2012 | 06:57 PM
gotz06?'s Avatar
gotz06?
Look at the harmonic balancer with the engine running and see if looks like it wobbles. If it does not look like it's wobbling then it is fine.
Old Jul 20, 2012 | 09:44 PM
torchredmadness's Avatar
torchredmadness
I agree with Vetteman. Think about changing all fluids and tires. All of that is a good chunk of change. But, after that it's just drive.
Old Jul 21, 2012 | 10:25 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Skip shift eliminator
Old Jul 21, 2012 | 10:51 PM
usgecko's Avatar
usgecko
Kill the steering column lock before it bites you
Old Jul 22, 2012 | 08:45 PM
C5FORFUN2's Avatar
C5FORFUN2
Post #1
Old Jul 22, 2012 | 08:54 PM
abflyboy's Avatar
abflyboy
the TIRES will leave you stranded
To What's next??
