I need to know what the proper offset is for an 18 x 9.5 on the front of a C5. I want to keep the wheel flush or inside the body. Thanks in advance for your help.
Offset should be 59mm. I have 265/35/18s on this size wheel. The lip is 1.5"
I think size and offset are different. I think offset is determined by the make of the wheel you are considering so a CCW wheel has a different offset than an Ace Slick wheel or a stock Z06 wheel.
Go to Tire Rack, put in your vehicle & shop for wheels. They will list the offset for the verious width wheels you choose.
By the way, I'm apparently Dyslexic... I have 265/35/18 tires on my 18X9.5 (59mm) front wheels, not 235/65/18s!
Be carefull, as the Tire Rack has a lot of wrong wheel info! My rear wheels are 65mm offset, but a C5 ZO6 calls for a 53mm offset. Had to look up a C5 coupe/vert rear wheel. Yet they insisted that a 53mm offset rear wheel was right for my car. That would of stuck out 1/2"
