'97 Fuel leak
Old Jul 28, 2012 | 12:42 PM
kactussjack's Avatar
kactussjack
Default '97 Fuel leak
I just developed a significant leak, drivers side. It appears to leak around the fuel module at the rear of the gas tank, maybe 6-10 drops /minute.
Does anyone know if this a relatively simple fix (new gasket/seal)?
Is it safe to drive to my mechanic (~15 miles)? I had an fire while driving in a '66 911 from a leaking fuel line.
Thanks for any input.
Old Jul 28, 2012 | 01:16 PM
kactussjack
Default fuel leak
The face of the gas tank is wet around the fuel module connection to it & the gas is dripping from the shield.
Old Jul 28, 2012 | 01:48 PM
WKMCD's Avatar
WKMCD
A dollar says it's the fuel filter. Pretty common and it runs out of the shield. Good news is the filter is easy to access on the early models. It's mounted to the frame above the wheel well. Simple fix.
Old Jul 28, 2012 | 03:04 PM
kactussjack
Default fuel leak
Can't get under there to see it.
Safe to drive to my mechanic's?
Old Jul 28, 2012 | 03:08 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Might be as easy as tightening the claps on the fuel tank crossover tube. Thats what happened to me last year drivers side. If your dripping fuel that much, i wouldnt drive it 15miles
Old Jul 28, 2012 | 04:21 PM
If it is not the fuel filter (easy to replace yourself) or a relatively easy tightening of some bolts, I sure wouldn't drive it anywhere with fuel leaking.
Old Aug 2, 2012 | 08:18 AM
kactussjack
Default Fuel Leak
Had the car towed to my mechanical. The seal around the fuel module is leaking. told him to replace the fuel filter while he is under there.
Thanks.
To '97 Fuel leak
