squeeks and rattles....got any?
Old Aug 3, 2012 | 06:22 PM
  #41
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by Z16 Zipper
none of the above BUT I do have a fan for the AC or Heater that when turned up above the first two bars sounds like it is going to lift off and go for a spin by itself. It just started could the squirrel cage fan be out of balance or a bearing on the motor be going out. Not sure how to get to it. any info would be great, thanks much.
I had that problem years ago, and it drove me nuts. Then one day a freakin' paper label flew out of the vent and the noise was gone!!!!
Old Sep 24, 2012 | 04:45 PM
  #42
NSTG8R's Avatar
NSTG8R
For the driver's door - I noticed the clips on the driver's door (the plastic ones that hold on the panel) were broken and part of the Styrofoam was cracked.
Originally Posted by DSTURBD
If you are going to do blatantly stupid ****, why not just tell your mom to spend twenty minutes a day in the microwave to get a tan?!?!?!?!?
...excessive much?
Old Sep 24, 2012 | 06:28 PM
  #43
whitesmokels1's Avatar
whitesmokels1
I just try to keep over 768mph, then I don't hear anything.
but seriously...
'98 with 152k.
1. windows when they are all the way down.
I just tap the up button to bring them up to the felt and it stops.
2. targa top.
Its usually off anyway.
I may have more but my exhaust is so loud I can't hear it.
Old Dec 10, 2012 | 07:32 PM
  #44
jaxmandueagain's Avatar
jaxmandueagain
8th Gear
Default squeek in suspension
Originally Posted by PoVette
01 w 72k miles.. The suspension squeaked when I first got it. Metal endlinks fixed that.. Now the only time I get a squeak is when I have the painted roof on.. Slow turns into parking lots I will get some squeaks.. Not enough to bother me tho.
I have a squeek in the rear right corner. It is mostly when cornering left or going over bumps and gets much worse as the tempratures get colder. My mechanic hasn't been able to recreate on the rack yet so haven't made any changes - does this match symptoms you saw related to the end links?
Old Dec 10, 2012 | 08:21 PM
  #45
bikeriderga's Avatar
bikeriderga
My 2000 rattled but my 03 Z06 does not.
Had squeaks in my 2000 roof and suspension. 86K on the 2000, only 22K on the 03 Z06, so a little different driving time.
Age not only affects us (as does mileage )it is also true of our cars.
Start replacing seals, tightening bolts, and replacing bushings. Might be amazed at high well that old paint will ride.
Old Dec 10, 2012 | 10:50 PM
  #46
VETTEV's Avatar
VETTEV
Originally Posted by Mr.Vicious
Windows rattles when all the way down...... H
I have to put them up a bit for it to stop.
Same problem here too... Wish I knew the fix
Old Dec 10, 2012 | 11:29 PM
  #47
corvettepete's Avatar
corvettepete
Once in a while from my targa top though it usually spends late spring, summer and early fall hanging on the wall in the garage. When I close the driver's door with the window down, a little noise. Other then that, after 13 years and just hitting 52K miles, it's pretty darn tight.
Old Dec 11, 2012 | 10:38 AM
  #48
64Corvette's Avatar
64Corvette
It's not a Corvette if it doesn't have a squeak or rattle some where!!
Old Dec 11, 2012 | 11:40 AM
  #49
sbulla's Avatar
sbulla
I, also, have a squeak in the right front of my '04 'vert (35000 mi) that seems to be temperature related. In cool temps (30-50) it'll squeak but, when it get's to around 60 degrees, it doesn't. Can't make it do it just by bouncing it with my body weight in the garage either.
Sonny
Old Dec 11, 2012 | 01:20 PM
  #50
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Originally Posted by RetiredSFC 97
yeah some, but mostly in my knees
You took the words right out of my mouth.
Old Dec 11, 2012 | 01:28 PM
  #51
jcsperson's Avatar
jcsperson
NC Events Coordinator
Originally Posted by 209TIME!!!
My suspension sounds like crap going over speed bumps I hate it!!!
Originally Posted by Corvette_Ed
Change your end links; and make sure to get the metal ones.
I had an annoying rattle that occurred whenever I hit about 17-1600 rpm. It sounded like it was coming from the hatch, but when I had my sway bars and shocks replaced, it went away. The old sway bar had metal endlinks, but the new one came with new endlinks so I used those.
I also have a very loud sound that comes out of my center a/c ducts under hard acceleration. It has a plasticky sound like a/c ducting or a panel is loose and resonating with the engine revs. It has an aftermarket head unit installed, so it might be that. I barely listen to the damned thing so I might go back to stock.
Old Dec 11, 2012 | 01:48 PM
  #52
knewblewkorvette's Avatar
knewblewkorvette
My 02 is pretty much rattle free but my 98 has developed a squeak coming from the hatch that is driving me nuts . Getting rid of that squeak is the first item on the "to do list" when I get her out of winter storage.
Old Dec 11, 2012 | 01:51 PM
  #53
Quickshift_C5's Avatar
Quickshift_C5
I have some dash rattles here and there, even more so when it's really cold out. But...the car is 10 years old, has super loud exhaust (lots of vibrations), and has nearly 700hp crank.
I can deal with a few squeaks and rattles.
Old Dec 11, 2012 | 03:02 PM
  #54
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
I did the metal end link / C6 Z06 & Z51 suspension upgrade on my '01 about 25k ago (car's at 120k now), and recently started noticing a rather loud squeak from the rear suspension when I go over bumps. Not sure what the best course of action would be (any recommended lubes?).
Also, for a long time, I've noticed a kind of "something's loose" rattle from under the dash / hood area on the driver's side whenever I go through dips or over bumps. No idea what the source of the noise is (kinda sounds like something hollow rattling), and it's been there since long before I did any mods that could've been the cause.
Old Dec 11, 2012 | 05:54 PM
  #55
Zora's Brother Joe's Avatar
Zora's Brother Joe
I am curious about the upgrade to the zo6 what parts did you replace ?? thanks Joe
Old Dec 11, 2012 | 06:02 PM
  #56
flaagan's Avatar
flaagan
St. Jude Donor '12
My car was a z51 to begin with (which doesn't really affect the overall change, just a reference). The upgrade is a set of C6 Z06 shocks combined with C6 Z51 sway bars and the metal end links. It's the fifth and sixth part sets here on gmpartshouse, where I got mine from.
I don't track the car or anything, so couldn't really justify spending well over a grand on coil-overs. It's considered a good overall upgrade to stock or z51 C5 suspensions, especially if the originals have a number of miles on them.
