twilight sensor location
Old Aug 3, 2012 | 08:33 PM
slimsol's Avatar
slimsol
Default twilight sensor location
Where is the sensor for automatic light is located?I know its somewhere on dashboard but i cant find it. There are couple sensor on rear view mirror and one dome shaped sensor on vent but none of them is for twilight.
Old Aug 3, 2012 | 09:12 PM
3sACROWD's Avatar
3sACROWD
You are looking past it. Locate the dome on the grill on the dash. The twilight sensor is on the opposite end of the grill towards the driver's side. It doesn't stick up. If you pull the grill up, you will find it. If you look at the grill through the windshield you'll see the hole for it.
