[Z06] zo6 cats
Old May 29, 2002 | 01:51 PM
jsingh's Avatar
jsingh
Default zo6 cats
since the cats flow a lot better on the Z does anyone know if they can be installed onto a 02 coupe without problems?
thanks
Old May 30, 2002 | 11:18 AM
BLISS's Avatar
BLISS
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: zo6 cats (jsingh)
yeah they can be, but why would u wanna go thru all that welding trouble? .... and #2 - The 01 Z has precats ... all cats on all vettes are the same,each year - as far as I understood it, when I was at the factory tour checking them out
Old May 30, 2002 | 07:31 PM
don527's Avatar
don527
Default Re: zo6 cats (BLISS)
Wrong.
'02 Z06s have new cats... without the precats.
Publications have quoted GM engineers saying that removing the cats are good for about 5hp.
That also accounts for the slightly deeper sound in the '02 Zs over the '01s.
They are a bolt-on affair... no welding. If you found one from an '02Z, it should bolt to a coupe or vert no problem. Les on the 'other' forum took the cats off his EB '02 Z and bolted them on his wifes vert.
Not cheap if you buy them new... approx $1300 I believe.
Don
[Modified by don527, 8:17 PM 5/30/2002]
To zo6 cats
