radio fried
Old Aug 4, 2012 | 02:56 PM
baxsom's Avatar
baxsom
Default radio fried
So I think my radio is fried. It happened while it was sitting with the battery unhooked at the shop during its head/cam install.
Now everything on the dash works like the HVAC, hazards, and the lights on the HVAC but the radio itself has nothing. There is no display, no lights, no LOC code nothing. I went ahead and picked up another one just in case but is there anything else I can look for? I checked in the fuse panel and the 20 amp fuse marked Bose is good and it has power going to it.
Old Aug 4, 2012 | 02:59 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Read your owners manual. I think that there is an anti theft feature on the radio that causes it to go dead if tampered with. There is a way the owner can unlock it if you have saved the code. Otherwise you have to get a stealership to unlock it.
Old Aug 4, 2012 | 03:04 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
If its locked you should see the lock message displayed. If there is no display it is probably something else.
Old Aug 4, 2012 | 08:16 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I belive there are two other fuses pertaining to the radio. I forgot how they are marked but should say on the panel by the footwell. If you can test with another radio to see if it works/doesn't work you can narrow it down.
Old Aug 4, 2012 | 08:43 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I've had many experiences with the radio. Try removing it, remove the connectors, then reinstall. Also, start and restart the car a few times. Also, try your spare each step of the way too.
Old Aug 4, 2012 | 08:59 PM
65GGvert's Avatar
65GGvert
There are two fuses for Bose, but they are for speakers. Fuse #5 is marked 'radio/cdplayer"
Old Aug 4, 2012 | 11:22 PM
Good luck and be sure to check all the fuses.
Old Aug 5, 2012 | 12:15 AM
baxsom's Avatar
baxsom
I missed #5.
this one fixed it right up. looks like I will have a spare now but that is ok.
To radio fried
