Water inside door shell.
Old Aug 7, 2012 | 02:15 PM
jrsgraphics's Avatar
jrsgraphics
Cruising
Default Water inside door shell.
Here's my issue:
Whenever it rains, or especially when I wash my baby, it seems that the door is filling with water. There is no water inside the cockpit. I can open and close the door and it looks like a quart of water will work its way out from the drain hole.
My guess is that the water is getting in between the window and the outer window seal. I'm aware that the door is not water tight but this seems excessive. The seal is flexible and not dry rotted but there is ~2mm gap toward the front.
Has anyone experienced this or had issues spurned from a water problem? Thanks.
03 Anniversary Coupe
