LS7 crate into 1999 C5?
At first, I thought it would be silly as you have to tear the new engine apart to change the crank sensor, and cam sensor, but then read Lingenfelter makes a converter box to work with the C5 electronics.
Seems I read that the A/C compressor pulley will not match up with the crank pulley, not sure about that.
The crate LS7 is not cheap, but, you get a lot, it already has the flywheel and clutch, coil packs, plug wires, injectors.
Looked into building a 454 LS from ERL, their 454 long block costs quite a bit more than the LS7 crate, still has no intake, injectors, coil packs, or exhaust manifolds/headers, all those parts add up quick.
So, looking at the crate LS7 more, it may be the best bang for the buck.
I'm wondering if the C5 accessory brackets will fit it, and PS pump, alternator, etc.
Guessing the LS1 motor mounts/stands will work with it, my car is a 6 speed.
On the pictures of the LS7 crate, it has the exhaust manifolds, but it does not appear to come with the exhaust flanges to bolt to the manifolds, and they have 4 bolts, so getting these may be a problem.
Have also considered keeping the LS1 and putting on a A&A supercharger kit, or a Magnacharger.
From what I read in the forced induction forum, neither of these can match the LS7, the first needs to get to 3K RPM before it gets going, so down low it's weak compared to the LS7.
The magnacharger might keep up down low, but up higher the LS7 will out pull it.
To be honest, I don't have the funds to do this right now, but just wondering how much trouble it would be.
I forgot to mention the wet sump VS dry sump oiling systems, for me I think going wet sump would be fine as it's just a toy, no real racing, just romp on it here and there.
My stock LS1 runs fine, it's just after driving a C6 Z06 for a few miles, in town, even down low it was much more fun!
What do you think?
Need the reluctor wheel converter box from Lingenfelter
Slight harness extension to C5 harness
Retune C5 ecu to run LS7
Some little odds and ends
C5 pedal works
I have a built LS7 on an engine stand I don't know what to do with. I ended up just putting an A&A kit on my C5Z. Was a simpler process and makes 578whp/512wtq. I beat up on C6Z's with it because the centrifugal pulls more like a hotter NA motor would versus a roots style blower. Plus, AA kit fits under stock hood. Figured I'd keep the LS7 for something I'm doing next year for SEMA.
C5 pedal works
C5 pedal works
You have to remember, your engine is quite a bit more powerful than mine stock for stock, mine only has 345 HP as yours was 405, then again maybe with a supercharger the lower CR of the LS1 can handle a tad more boost so it evens out?
Was thinking the LS7 would be more consistent than the LS1 with supercharger, maybe not, it's just after driving the C6Z06 for a short trip, I really liked the car.
I wanted to get a C6 Z06 and then thought about it, and the reason is the engine's power, honestly I like the C5's looks better, the fact there is a crate LS7 available is pretty cool, if it was not available and the only way was to get one from a wrecked C6 Z06, I would not even consider this project.
It seems the only thing that would make a LS3 swap easier than the LS7 is no dry sump oil system to make fit?
I have a 1965 Chevy truck short bed, that the LS1 would be perfect for, so the LS1 would still live on!
easiest and best for resale is a direct ls3 swap.
the other thought is selling your c5 and buying an ls3 c6 which can be had for high 20s. that's not far off what you could sell yours for along with all this engine money. you would also have more resale in that c6
Or build a stroker 402/418 and make more power than an LS7 too.
I'd say switch to the LS3. It would be easier, 85 more hp is a lot and I'm pretty sure you'd be happy with it.
If it didn't last (the thrill I mean) you could still put an A&A on it, you'd probably still have less invested than the LS7 swap out, and you'd be way over the LS7 in hp.
Just an thought, and of course, JMHO
What do you think?
If you relocate the battery to the trunk, there is a ECM below it right?
I wonder if the remote oil tank could fit there.
