A/C Compressor Replacement
Old Aug 11, 2012 | 01:09 AM
Trios's Avatar
Trios
Default A/C Compressor Replacement
So, long story short, my compressor is failed. What should I expect to pay for a new one, installed, with flush and refrigerant?
Any ballpark estimates on all of the above including replacement of the serp. belts and tensioners? I think while they have all that out they might as well replace those wear items; I know they're at least at 40k miles and possibly original at 100k.
Should I have this work done at a Chevy stealership or an A/C specialty shop?
Thanks!
Old Aug 11, 2012 | 07:10 AM
Grizzly Ben's Avatar
Grizzly Ben
Was in the same boat 2 months ago. Gladly i found a AC specialty shop that knows Vettes.
They rebuilt the original compressor, instead of putting a new ''chinese'' one.
Cost me near 1K$. System running perfect.
Old Aug 11, 2012 | 07:36 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
certainly not $1K ..even a new one from GM partshouse is just under $500 so unless they can find a way to charge you $500 in labor and 2 belts
probably need to ask in the regional section of the forum...see if anyone up you way has some ideas of a place to go
Old Aug 11, 2012 | 07:55 AM
Fast one's Avatar
Fast one
http://www.rockauto.com/catalog/raframecatalog.php They have both GM and other brands of compressors as well as the other AC parts you might need.
Old Aug 11, 2012 | 12:40 PM
Trios's Avatar
Trios
So, the $1k paid above made me think twice about having a shop do this work - however, the service manual calls out to remove the water pump as part of replacing the a/c compressor? Is that correct?! If so, again I think I should let a shop do it..and I probably should have the shop replace that water pump while they're in there. The car is just 500 miles shy of 100k and she ain't getting any younger after all..
What says the forum?
Old Aug 11, 2012 | 02:33 PM
Vettmann17's Avatar
Vettmann17
Let an A/C shop do the work. Bringing it to the dealership will no doubt cost you more. I wouldnt recommend doing the work yourself as it is a pretty big job unless you are experienced in A/C repair. Changing out the water pump is a good idea since it has to come out anyway but will add a few hundred dollars more to the price. Prepare yourself to pay about 1500.00 or more with the WP. If you don't use the A/C that much then wait till next year so you can slowly put aside the $$ so it wouldnt be such a big hit all at once. Whatever you decide good luck with the job and I hope you get it done right for a good price.
If your curious about what the job entails check out the link below.
http://www.digitalcorvettes.com/foru...ght=compressor
Old Aug 11, 2012 | 05:46 PM
Trios's Avatar
Trios
Well, I have done some a/c work, so I already have a set of quality manifold gauges, a vacuum pump, and a 30 pound bottle (with probably 25 pounds left) of R134, so I think I'm okay to do the work myself.
Here is a picture of my RockAuto shopping cart - does this look about right to everyone?
Old Aug 11, 2012 | 06:56 PM
pewter99's Avatar
pewter99
I talked to my mechanic today about this and he said, "$1000?? I need to start charging more.."
Old Aug 11, 2012 | 08:50 PM
Ron C!'s Avatar
Ron C!
Consider doing the water pump as well, it has to come out to remove the compressor.
Old Aug 11, 2012 | 11:47 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
If you already have those A/C tools, I'd say just do it yourself. I just did mine a few weeks ago, new compressor, orifice tube and new dryer were $28x.00. Water pump gaskets need added in. I don't know what a water pump costs, but I'd let it on unless it was broke. As to pulleys and tensioners, the pulleys are 20-30 each, tensioners are $70 each. Be sure to remove the belts completely from the car before removing any coolant hoses or the water pump. If they get wet, they're done.
The job isn't that bad. I did mine on ramps. Very little time underneath. If yours failed though, you'll need a flush kit for sure. Might want some other opinions on flushing the condenser. Some folks say it can't be done if you have a particular type (smaller holes).
Old Aug 27, 2012 | 07:40 PM
Trios's Avatar
Trios
Figured I'd update this thread for anyone who searches for it in the future.
I finally got access to the car for a weekend (its my wife's DD, and she works Sundays so I had to convince her to drive the truck. Not hard to do when the a/c doesn't work in the 'Vette thoough). I have to say, replacing the compressor was a PITA. Not because any particular step was all that difficult (although the 13mm bolt on the back of the compressor that holds the lines on was a bitch), but mostly due to this being a Corvette and there being very little room to work. My hands and arms are all sorts of bruised from trying to work a ratchet in the various areas.
I also replaced the reverse lockout solenoid while I had the car on stands, and of course the new water pump went in because 100k miles is plenty for the old pump to handle.
Anyhow, 1 new compressor, 1 line flush, 8 ounces of new oil (2 in compressor, 2 in accumulator, and 4 added to the lines in places to make up for the flushed oil from the condenser & evaporator), and 20 ounces of R134a and we have cold air again.
Thanks for the encouragement.
Old Dec 19, 2012 | 07:48 PM
DevilMan02's Avatar
DevilMan02
Thanks for updating this post, my compressor just failed tonight on my way home from work
It smells AWFUL. I opened up the hood and looked down to see a little smoke coming from far below the coolant tank and saw something was glowing red!
I assume I'll be replacing the compressor entirely, water pump too since I've also been having some overheating issues. Perhaps this will fix both.
Thanks again!
Quick question: are there any brands of waterpumps and or compressors which are superior to OEM?
Old Dec 19, 2012 | 10:35 PM
YearOneC5's Avatar
YearOneC5
A month ago, the A/C compressor "clutch" failed, not the compressor itself. Caused the same "smell" I think you are describing. Basically if you try and run the A/C while the "clutch" on it isn't working correctly, it causes the smell. Until you fix it, I would just keep the A/C off.
I bought a complete new A/C compressor from Autozone for $318, and also bought a new A/C belt ($20) and the two "metal with rubber ring" water pump gaskets ($20) from O'reillys (recomended over the paper water pump gaskets).
Paid for four hours labor ($80 per hour) to have it installed $320.
Paid $100 to have the system evacuated and recharged.
So all in looking at aproximately $800, unless you can do the labor yourself on both the install and evac/re-charge.
To A/C Compressor Replacement
