Cleaning the radiator on a C5
Old Aug 12, 2012 | 12:41 PM
doubleD's Avatar
doubleD
Default Cleaning the radiator on a C5
I've made me a tool to flush the trash from my radiator. Is it easier to clean from the top taking the shield off or going under and doing it that way. Explain please. Thanks
Old Aug 12, 2012 | 01:05 PM
sfc rick's Avatar
sfc rick
I pulled the plastic shroud in front of the radiator out from the bottom giving me full access from the front. I also pulled the top piece connecting both radiator and condenser together. This allowed me to lower long air blower between both radiator and condensor and throughly clean AND SEE that they are clean. Was able to lower shop light behind radiator and look through them from the front and see all the way through, to check how clean they were!
Old Aug 12, 2012 | 01:27 PM
doubleD's Avatar
doubleD
Thanks, I'm in the process of removing the top covering now. Will those 2 plastic keepers on top come out or will they break. Can they be re-used?
Old Aug 12, 2012 | 02:47 PM
sfc rick's Avatar
sfc rick
Not sure, I no longer have a stock air bridge since I tossed it and use a Vararam.
Old Aug 12, 2012 | 03:01 PM
doubleD's Avatar
doubleD
Thanks Rick
Old Aug 12, 2012 | 09:20 PM
jrose7004's Avatar
jrose7004
I always go in from the bottom.
Old Aug 12, 2012 | 10:56 PM
LastC3AZ's Avatar
LastC3AZ
I always go in from the top ..... and use one of these ......
To Cleaning the radiator on a C5
