My 99 is running hot and I'm not sure the fans are working properly. Can someone pls explain proper ops (on temp, single vs dual ops, etc) so I can better understand what is or is not working?
You do not have to cool it down, the cars is functioning correctly. You can try to clean the outside of the radiator, a lot of junk collects in/on the cooling fins.
The Vettes are bottom breathers and pick up a huge amount of garbage in the AC condensor and radiator fins. I clean mine out annually and usually get several handfuls of garbage out. I remove the top radiator shroud and use a 90 deg air nozzle like the one in this link to blow everything out. http://www.buy.com/prod/mountain-mtn...212940104.html. If you just rely on the hose from the inside, there are large areas that you can't get to because of the fan shroud. You have to do the condensor and the radiator separatly to get it all out.
Thanks CHJ.
I am the third owner of my 99. The first owner did quite a number of mods including replacing the OE air filter. In order to accommodate the depth of the large KN filter, there is a 10" x 10" cutout in a metal plate that covers the radiator. This cutout includes a piece of shaped sheet metal that drops down about 1" towards the condenser/radiator.
I'm thinking that this is obstructing air flow to the condenser/radiator and driving up temps.
Where can I find a pic of the correct radiator shrouds so that I can compare with mine to see if I can better understand this?
Thanks CHJ.
Thanks again.
Does it look like a scoop? if so that is not it then. I have the same thing and my temps are 180-200
It's not a scoop - it's more like a depressed square pan. I looked underneath and there is plenty of room between the backside of this depressed pan and the front of the condenser. So that's not the problem.
I hosed the front of the condenser, the back of the radiator and the space between as best I could. There was some grass, etc in the radiator but not much.
Is there supposed to be a foam seal between the condenser and Radiator? When I rebuilt the cooling and AC systems on my C3, many recommended sealing the space between the two to insure that air came thru the condenser and did not go around the edges of the condenser to go thru the radiator. Does the same apply to the C5?
My AC works great so apparently the condenser is getting plenty of air now.
