Odd question and need a expert answer, please
Old Aug 15, 2012 | 08:30 PM
killain's Avatar
killain
Oldtimer
Default Odd question and need a expert answer, please
I'm in the process of changing my console and I swapped out all the electrics on the console trim panel, the "Traction Control switch & the magnetic ride control **** and the "Passenger airbag light" which I can't remember it ever being lite, how does the Passenger airbag light work ? What do you do to enable the passenger airbag light to be lite or is the passenger airbag always enabled ? Thank you !
Jim Ward
Old Aug 15, 2012 | 08:55 PM
You should have a switch located in the glove box that you use your ignition key to turn the pass air bag off and then back on. It is set to be always on if you don't turn it off.
Old Aug 15, 2012 | 10:56 PM
killain's Avatar
killain
Oldtimer
Default Hum !
Thank you Sir !
To Odd question and need a expert answer, please
