HELP WANTED how remove brake booster
Old Aug 17, 2012 | 01:57 PM
Steve@C56's Avatar
Steve@C56
Default HELP WANTED how remove brake booster
Installing kooks 2", having put off quite half part of the car (complete post coming soon) , and THE LAST part is the brake booster !
The 4 15mn nuts are remove
The pedal stud is loose
And... the brake booster DONT COME OFF !!!
Have double check 10 times, the 4 nuts are realy not here !
By moving the brake booster on motor side, it's quite the up passenger nut was here !
Have use hammer, with not succes
H.E.L.P.
thanks a lot
Old Aug 17, 2012 | 04:05 PM
robert miller's Avatar
robert miller
Default ttt
If you got the 4 bolts out from it man it takes a long ext to get back there. There is a tin really tin washer that holds it in place. Just really pull like hell and it will come out after you get those 4 bolts out. Dont worry you dont use are have to get a new tin washer. But it is a bitch to pull it out. really I just did this a month are so back to get my KOOKS on the car....If you want to call me 931-528-1999 just ask for me...Robert
Old Aug 17, 2012 | 04:38 PM
alextz's Avatar
alextz
its those washers, pull real hard and it will go.
Old Aug 17, 2012 | 05:30 PM
Steve@C56's Avatar
Steve@C56
Thanks A LOT robert...
I know for your kooks ;-) I know what you have (all) done You know what i have (all) to do
The cradel is down, the car is on jack (of 24 inch as kooks said, but dont understand why as up as they said ??? but i know their process notice is not "the" process, since 3 day (8h per day working on), but the car is not so stable than i wonder, so, i have hard pull the booster (the car was moving) but not like hell
I have to put more jack, no choice
THANKS !
Old Aug 17, 2012 | 05:32 PM
Steve@C56's Avatar
Steve@C56
I will, thanks !
Old Aug 18, 2012 | 07:14 PM
Steve@C56's Avatar
Steve@C56
With 1 or 2 hours of big hammer job... HAVE IT
In fact, just two studs was killing me, the up-right and the down-left
Thanks !
To HELP WANTED how remove brake booster
