[Z06] Ranges for oil pressure
Old Aug 22, 2012 | 11:57 AM
Dollard's Avatar
Dollard
4th Gear
Default Ranges for oil pressure
Just wanted to know were the ranges are for oil pressure. My Z06 is superchaged and the oil pressure will be high like around 55-70 and then fall to around 40 then when i stop at a light the pressure will drop down to like 25-30 and have seen it as low as like 20 or 22psi so what do you think also i run 5w- 30 in the Z06 what do u guys think!!!!
Old Aug 22, 2012 | 01:11 PM
Dennis Wilson's Avatar
Dennis Wilson
Sounds pretty normal.
Old Aug 22, 2012 | 01:18 PM
Dollard's Avatar
Dollard
4th Gear
Default new to corvette forums
Hey yes i am new to corvette forums so help me out im not sure were the oil pressure should be or if this is normal. also i do under stand that once the oil warms up that the pressure will drop but the 25 psi on the dash worries me let me know!!!!!
Old Aug 22, 2012 | 04:07 PM
SOMFormula's Avatar
SOMFormula
That's normal
Old Aug 22, 2012 | 05:12 PM
KillSwitchNY's Avatar
KillSwitchNY
16psi idling @ normal temp. It also has oil being ditributed to 2 turbos, scavenge pump and an oil cooler. I run 5w30 Amsoil. Switching to 10w30 or 15w50 Mobil in a few days.
Old Aug 22, 2012 | 08:14 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
In a modified engine out of warranty, I'd consider this which is very similar to AMSOIL's racing 10w30 I use, but has enough detergent/dispersant for about 3-5k oil change intervals whereas I change the racing oil about every 500 miles.
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
Biggest difference between this and any API SN spec oil is the extra anti-wear additives (zinc and phosphorus or ZDDP).
FYI, Mobil 1's ZDDP numbers available here:
Mobil 1 Zinc/Phosphorus Levels
All that said, the oil pressures are not that abnormal. What they really indicate is the oil's viscosity and the engine rpm (which drives the oil pump). The hotter the oil gets, the more its viscosity drops, thus the lower the oil pressure. This is why you see in the low 20s at idle when the oil is really warm.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 23, 2012 | 02:51 AM
LoneStarFRC's Avatar
LoneStarFRC
Look pretty typical/normal to me!!!!
To Ranges for oil pressure
