Holley high ram intake
Old Aug 27, 2012 | 07:08 PM
skull's Avatar
skull
Default Holley high ram intake
has anyone tried fitting one of these on a c5? such a bad *** intake for the price and woundering if anyone was able to make one work and what was required.
Old Aug 27, 2012 | 07:12 PM
momo20's Avatar
momo20
other then the fact this stands out to me hood restrictions are NOT a consideration..i really dont see a point in this intake set up..
Old Aug 27, 2012 | 07:14 PM
skull's Avatar
skull
BOOST!!!!!
well i was woundering if someone just cut the hood to fit (which i would prolly do) or what hood they use to clear, how much of the cowl they cut
Old Aug 27, 2012 | 08:48 PM
momo20's Avatar
momo20
i was looking for a bit at work and could not find any thing on how far it sets up off the motor..so it would be a guessing game till you could get one..i would rather spend some extra coin and get the fast setup..imo
Old Aug 27, 2012 | 11:27 PM
skull's Avatar
skull
Yea I already have a fast 90
Old Aug 28, 2012 | 12:38 AM
C5Natie's Avatar
C5Natie
I believe that intake is 12.32in tall from its base to the highest point. Youre gonna need a big a$$ cowl to clear that.
DIMENSIONS:
NOTE: All heights measure to the lifter valley cover flange on the engine block.
NOTE: Unless otherwise stated, the dimensions and information applies to all LS Hi-Ram applications LS1/2/6, LS3 and LS7.
 Total Height with 92/102mm Long. Mount EFI Plenum Top – 12.32”.
 Port Size: LS1/2/6 – 3.18” Height (includes injector tunnel) x 0.98” Wide.
LS3 – 2.49” Height x 1.21” Wide.
LS7 – 2.33” Height x 1.30” Wide.
 Mounting Flange Gasket Type:
LS3 & LS7 – 3/32” Round Viton O-Rings, Size 2-146, 2-5/8” I.D. (included with the int. man. install kit).
LS3 – Runner Length - 6.50”
As-cast Runner CSA - Tapered, 4.25 in² at the entry to 2.77 in² at the port flange.
ge.
http://www.holley.com/data/Products/...R10572rev4.pdf
Old Aug 28, 2012 | 12:50 AM
skull's Avatar
skull
So yea to run one I would most likely just be cutting a hole in the hood lol what's the height of a ls6/ fast intake to know how much taller it is
Old Aug 28, 2012 | 06:57 AM
cvm's Avatar
cvm
Skull you really need this intake!
I live in Monrovia and I could buy your 90 real cheap to offset the cost.
And pik it up to save you the shipping hassle!!
(prob a weak attempt @ 7am to make us both laugh..)
Mark
Old Aug 28, 2012 | 07:11 AM
skull's Avatar
skull
Mark
Lol I think Imma hold onto the fast for a little bit before making that commitment to cut a hole in my hood lmao. Does anyone know of a comparison dyno of a 90 fast to a high ram
To Holley high ram intake
