Need to do more??
Old Aug 28, 2012 | 11:13 PM
FRITZM's Avatar
FRITZM
Default Need to do more??
I AM DOING THE LS1/LS6 INTAKE SWAP AND THE VALLEY COVER PCV SWAP ALSO. WHILE I HAVE THE MANIFOLD OFF I WILL ALSO BE DOING THE OIL PRESSURE RELOCATION TO FORESTALL OR ELIMINATE ANY POSSIBLE NEED TO REMOVE THE MANIFOLD AGAIN IN THE FUTURE. WHILE THE HOSES ON THE BACK OF THE MANIFOLD LOOK OK, THE VERT HAS 73K ON IT AND LOOKS CAN BE DECEIVING, SO I AM GOING TO REPLACE THOSE AS WELL. CAN ANYONE OFFER ANY OTHER MODS/CHANGES THAT I SHOULD DO WHILE I AM AT IT WHICH WOULD OTHERWISE NECESSITATE REMOVING THE MANIFOLD AT A LATER DATE? THANX FOR YOUR OPINIONS/COMMENTS.
FRITZ.
Old Aug 29, 2012 | 04:17 AM
high wire's Avatar
high wire
First , try turning off the CAPS. Second , add a couple of inches to the small vac. line at the back of the manifold.
Old Aug 29, 2012 | 06:33 AM
Cybermind's Avatar
Cybermind
You should change out your passenger side air-check valve. It's located all the way in the back of the intake manifold and it is known to gunk up and go bad pretty quickly.
Old Aug 29, 2012 | 06:42 AM
memmer's Avatar
memmer
I am called fritz and my last name is mason so you might say that I too am FRITZM LOL
Fred
Old Aug 29, 2012 | 12:38 PM
FRITZM's Avatar
FRITZM
Default Caps?
What is caps? Pardon my ignorance.
Will add to hvac vacuum line, thanx.
Nice to meet you fritz.
WILL LOCATE PASSENGER SIDE AIR CHECK VALVE AND CLEAN/REPLACE IF NECESSARY
THANX TO ALL, FRITZ.
To Need to do more??
