Windshield Chip Repair
Old Aug 29, 2012 | 09:36 PM
CLEAR's Avatar
CLEAR
Default Windshield Chip Repair
Anyone have luck getting windshield chips repaired so they are invisible? In the past when I got them filled they still looked the same. Safelite is the only place that claims to make them invisible. BTW my chip/star is about a nickel size.
Old Aug 29, 2012 | 11:32 PM
Blown 346's Avatar
Blown 346
You might still see it with it being that size. At least I did with my truck. It filled it in butting looked basically the same with the outline.
Old Aug 30, 2012 | 09:19 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I had a chip repaired by Safelite and it is far from invisible.
My one and only chip bounced off my hood and then chipped my windshield right in the HUD line of sight. My insurance company covered the repair, however all Safelight did was insert the clear gel to prevent the chip from expanding or further cracking. I had originally thought they had a process to heat up the windshield that would then melt the chip away and reform the glass. However that's not how they repaired mine.
No biggie, it just sort of bugs me that the windshield is flawless with the exception of this one chip. What's worse is that I remember the moment I got the chip from a beefed up 4X4 Jeep with donut off-road tires spitting gravel through a construction zone.
Old Aug 30, 2012 | 09:35 AM
TOPCATHR's Avatar
TOPCATHR
i had a chip fixed at the right side post near the top. it was ok but not invisible if it were in my view i would have changed the glass....my 2 cents
Old Aug 30, 2012 | 09:41 AM
I've had several windshield chips repaired and while they looked much better than before, you were still able to see a trace of the chip and Safelite did the repair on the windshield. Perhaps the skill of the technician comes into play, but the chips on mine were not totally invisible.
It sure beat having to replace the entire glass though.
Old Aug 30, 2012 | 09:55 AM
MSG C5's Avatar
MSG C5
Sort of makes me wonder if I can get a better outfit to "repair a repair" and actually improve on the original work performed by Safelite?
Old Aug 30, 2012 | 01:28 PM
high wire's Avatar
high wire
No , you can't fix it twice. The process creates a vacuum to draw the material into the cracks. You may be able to scrape it with a razor blade if it is not smooth though.
Old Aug 30, 2012 | 02:21 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I had one fixed a few years ago. I could still see it and the guy who did it scratched my hood due to carelessness.
I said I would never get another one fixed, but wait until it spread and I could get the windshield replaced.
Well, a few years later, I had a Blazer that had one and I didn't want to pay for a windshield, so I bought one of the Loctite kits for $5 or $10 and tried it myself. It was as good as the repair I paid for, but still not good. The only thing it accomplished was that it kept damage from cracking across the windshield until I sold the Blazer a couple years later.
Old Sep 16, 2012 | 07:46 PM
CLEAR's Avatar
CLEAR
I called everyone in my area to see what they thought. I got people saying that it would look the same to 50% better to 90% better. Safelite had no gaurantee. Glass Doctor told me that it would be nearly invisible then I showed up and he said 50%. I went to another place and he told me 90% so I let them do it. The "legs" are truly about 60% less noticible. The center is less about 50% better but the worst looking part is where he drilled it out first. The drilled part is black about the size of a pencil tip. I think if it hadnt been drilled the center would look better but I dont know if the drilling makes anything else better. All in all im about 50% satisified with the looks and do have peace of mind that it wont get worse.
To Windshield Chip Repair
