Torque battery cable on the engine block
Old Sep 4, 2012 | 11:24 PM
thedudeman's Avatar
thedudeman
Default Torque battery cable on the engine block
Hello, as the title suggests, I need the torque value for the negative battery cable grounded on the engine block. I assume it's 11 ft lbs the same as all the other battery torque values I've seen, but I wanted to confirm. Thanks guys!
Old Sep 5, 2012 | 02:03 AM
Jistari's Avatar
Jistari
http://dl.dropbox.com/u/1634366/C5torque.pdf
Old Sep 5, 2012 | 09:05 AM
thedudeman's Avatar
thedudeman
Thank you, I see torque values for the Negative Battery Cable on the Differential, Transmission, and the Clutch in that pdf. However, not on the Engine block. Does anyone know what it is supposed to be on the Engine block? Thanks!
Old Sep 5, 2012 | 11:32 AM
PUMP03's Avatar
PUMP03
Oldtimer
if your asking about the "Negative Battery Cable Ground Nut" (8mm thread) on the engine block, it is 71-lb-in
The torque for the "Negative Battery Terminal Bolt" (10mm thread) is 11-lb-ft just like either positive or negative Battery Cable to Battery Bolts.
The nomenclature gets a bit confusing.
Old Sep 5, 2012 | 03:40 PM
thedudeman's Avatar
thedudeman
Just to be sure I'm understanding this, you are saying it should be 71-lb-in (inch pounds, NOT foot pounds)?
Old Sep 5, 2012 | 10:00 PM
PUMP03's Avatar
PUMP03
Oldtimer
Yes that is 71-lb-in or 8-N-M
Attached is a jpg extracted fronm the Fastener Torque specs
You can go to post #4 in the following thread to get the whole enchilada
http://forums.corvetteforum.com/c5-t...post1581456859
To Torque battery cable on the engine block
