Will these fit without rubbing?
Old Sep 5, 2012 | 05:16 PM
bambo2888's Avatar
bambo2888
Default Will these fit without rubbing?
Will this wheel/tire combo fit a C5 non-z?
FRONT: 18X9.5 -- 275/35/18
REAR: 19X12 -- 325/30/19
Ideally, without rubbing... ever.
Old Sep 5, 2012 | 05:22 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
It all depends on what wheels your running. If you have the right offsets, the 275 will fit fine in the front, the rear on the other hand will not. You either have to tub the rear or go with fender flares...(as far as I'm aware)
Old Sep 5, 2012 | 05:43 PM
I do think you will have problems with the rear fitting without rubbing.
Old Sep 6, 2012 | 08:23 AM
bambo2888's Avatar
bambo2888
These are OEM c6 z06 wheels... but i think with larger tires?
Old Sep 6, 2012 | 08:27 AM
STALION's Avatar
STALION
So the fronts will fit, but come out slightly...the rears will fit, but again will stick out quite a bit without flares. I know 325 will fit, but not 100% sure about 345. It will be close! If you search the forum you should find some pics of guys who have done this without any modifications...some like the look, but many don't.
To Will these fit without rubbing?
