gas additives
Old Sep 5, 2012 | 10:22 PM
johntouhy's Avatar
johntouhy
Default gas additives
info on what gas additives are recommended for lsi 350 cu
Old Sep 5, 2012 | 10:37 PM
itzza427's Avatar
itzza427
Premium gas,,and an occasional bottle of Chevron Techron every now and then. Depends a lot on how much you drive it. I throw one in 3 or 4 times a year. Helps prevent the dreaded gas gauge syndrome!! Other than that none are necessary. Top tier rated gas is a good idea too!
Old Sep 5, 2012 | 10:48 PM
andrec10's Avatar
andrec10
StarTron as a fuel stabilizer. Works better than Stabil.
Old Sep 5, 2012 | 11:02 PM
jrose7004's Avatar
jrose7004
91 octane 100% gasoline and a bottle of Techron every now and then.
Old Sep 5, 2012 | 11:04 PM
NukeC5's Avatar
NukeC5
I trust Techron. Standoffish with the rest...
Old Sep 5, 2012 | 11:56 PM
cadmando18's Avatar
cadmando18
I've had really good luck with Lucus products. The fuel additive works great for me. I notice about a mile per gallon or more at fill up. I've used it with every car I've owned with great success. Turbo cars, little beaters... my vette... never had a negative thing happen. Just more power and better fuel mileage.
Old Sep 6, 2012 | 12:05 AM
leebay's Avatar
leebay
It good stuff...
Old Sep 6, 2012 | 02:15 AM
Jistari's Avatar
Jistari
Techron or SeaFoam (<==also very good).
Old Sep 6, 2012 | 02:42 AM
Ronnie wilkins's Avatar
Ronnie wilkins
Default dreaded fuel gauge problem,
I had the fuel gauge deal and Techron fixed me right up. i wonder if it cleans up the sender what else is it cleaning? Does it do the whole fuel system,lines, injectors also?
Old Sep 6, 2012 | 07:50 AM
runner140*'s Avatar
runner140*
I use a 20oz can of Chevron Techron concentrate every 5000 miles. Also use a can of Sea Foam once a year.
Old Sep 6, 2012 | 11:43 AM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Old Sep 6, 2012 | 01:56 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
No such thing as a LS 350 engine
Old Sep 6, 2012 | 02:21 PM
I use Techeon but both are good.
Old Sep 6, 2012 | 03:38 PM
OkieBikerDude's Avatar
OkieBikerDude
Take it from a couple of Okies, we know gasoline.
OBD
Old Sep 6, 2012 | 03:46 PM
racebum's Avatar
racebum
techron or lucas injector cleaner are fine. that stabil crap isn't, leaves massive deposits in the engine. coats the hell out of the piston tops and valves with the red slime tarnish
Old Sep 6, 2012 | 04:00 PM
killain's Avatar
killain
Oldtimer
Default Gasoline additives ?
Originally Posted by TheVettePirate
This is definitely the best way to go for a LS1 or any other engine. Use very good gasoline, 91 octane and throw in a 21oz. bottle of Chevron three or four times a year and I've had excellent experience from this practice.
Jim Ward
To gas additives
