Ok so I am running stock 295 35 18 size fire hawk wide ovals on my 03 z! So my ? Is what size can I safely run on a car that I do not race I don't want to rub but would like to fill my fender wells up! Also what brand do you recommend for better traction and still a good life span because I do use my car on trips sometimes?
Nitto NT05's are very popular street/track tires. I'm running them up front in 275/40/17 but have a set of Goodyear emts out back that came with the car. I want to get a set of NT for the rear to match soon. The NT is available in a 305/35/18 which fit no problem, that's what I'll get. Guys run 315's without issue, that's about as big as you want to go without running into issues with them rubbing.
Ok thanks man u had a set of bf Goodrich g force on the rear when I bought the car but u can't get them in a front tire size the wide ovals are jUnk when it comes to WOT!
I can't comment much on tires that offer longevity (I run R888s and R6s on the street), but I would very much suggest going with a 305/35/18 on the back.
I feel like this is the optimal size on Z06 wheels. They run wider than the stock wheel, and have a nice amount of sidewall which I find is both more visually appealing and better for traction (which you lose if you opt for the 315/30).
I ran these when I had Z06 wheels and was quite content.
Yes. More sidewall (generally) means a less harsh ride.
Hey I'm just keepin the stock size on my 01'Z for now. Any good replacements for the OE? They're pretty expensive but I will pay for them if I'm gonna sacrifice any performance. I'm up in the NW so I gotta keep wet roads in mind.
If you are in the North West you need to buy Vredesteins! They have great traction in the dry and the very best traction in WET! I lived in the Seattle area for 5 years with my 02 as a daily driver and ran them and had 0 problems on I5 no matter what kind of rain was falling never ever hydroplaned.
Another great thing about the Vredesteins are they are not expensive and I put 55,000 miles on my rears before replacing and the fronts now are at 60,000 with more to go.
DON'T BUY ANYTHING ELSE!
Ah man that is EXACTLY why I love Corvette Forum because of people like you red! Ill have to grab those Vredesteins.
Bridgestone Potenza RE 760. Put a set on from Tire Rack about a year ago. Get grip dry or wet.
I love them but they do not like water. 4th gear 30 MPH during a light rain on asphalt and the car starts going sideways at WOT.
From what I can tell the nto5s are just a drag radial I drive My car on several 3 to 4 hr trips and occasionally on 8 to 10 hr trip I don't know if these would hold up to several thousand miles and if I get caught in the rain! Is there a better option of a street tire that I can use and still get good traction if I want to run the car hard occasionally?
I think what you are looking for may be the bf goodrich gforce kdw, the rubber is not as soft as the nt05 and therefore should last way longer, the treadwear is 300 on the bfg and 200 on the nt05, plus i believe the bfg is way better on wet roads....but im sure there might be other brands out there too
Vredesteins are your best if sticking with stocks sizes (close to stock) and you are not tracking the car. On z06's you also have to worry about the tires rubbing through the brake ducts.
You have made a wise choice! When I bought my Z it had the stock Goodyears and they were flat dangerous in the rain. With the Vredesteins you can actually stand on it a little in the rain and not crash! I was totally amazed on how long they lasted but found out when I found a local tire company here that carried them in Phoenix that it is normal for this tire if not tracked.
Bf Goodrich kdw 2 I think I want these front and rear I can either run 275 40 17 and 295 35 18 on rear or does anyone know if a 335 30 18 will fit and look ok on the rear?
