question about seafoam
Old Sep 14, 2012 | 09:19 PM
johntouhy's Avatar
johntouhy
Default question about seafoam
what,s the best way.put it directly into the gas tank or into oil.
Old Sep 14, 2012 | 09:32 PM
cadmando18's Avatar
cadmando18
I've never heard of it being put into the oil. I've heard it being sucked into the vacuum system with a loose vacuum hose, I've heard it being put through the gas. I've also heard once you put it through the air intake system and the vacuum lines, and clean the intakes out, you need to change the oil.
Never heard of putting it in the oil though... doesn't sound like a good idea to me.
Old Sep 14, 2012 | 10:14 PM
momo20's Avatar
momo20
To clean built-up oil residues and contamination from the crank case, add 1½ oz. Sea Foam to each quart of engine oil. Sea Foam will slowly re-liquefy residues and suspend contaminants for easy removal. Monitor oil for color and clarity and change oil and replace filter when oil looks dirty.
http://www.seafoamsales.com/how-to-u...treatment.html
Old Sep 14, 2012 | 11:07 PM
LT1driver's Avatar
LT1driver
best bet don't use it, worthless for anything but smoke....if you must do something get gm top end cleaner...good luck whatever you do.
Old Sep 14, 2012 | 11:17 PM
racebum's Avatar
racebum
quality synthetics won't leave deposits in the engine, crud up the ringlands or get sludgy
seafoam is most often used to clean out pcv vapor sludge in the intake manifold.
To question about seafoam
