[Z06] C5Z on N20
Old Sep 18, 2012 | 08:10 PM
Silnus's Avatar
Silnus
Default C5Z on N20
Hand ported 243s, cam, full exhaust, etc etc with a 100 shot. 505whp 555tq. Ill be stepping up to bigger pills very soon.
http://www.youtube.com/watch?v=nnliU...ature=youtu.be
Old Sep 18, 2012 | 09:00 PM
ssrallyred's Avatar
ssrallyred
Cool, what kit are you using ?
Old Sep 18, 2012 | 10:36 PM
skyavonee's Avatar
skyavonee
That cam sounds real nice - what are the specs?
Old Sep 18, 2012 | 11:21 PM
Silnus's Avatar
Silnus
NX shark nozzle right now nad the cam is a custom 232/236 .625 X2 112
Old Sep 19, 2012 | 02:16 AM
skeeters65's Avatar
skeeters65
Car only makes 405 with out spray?
Something isn't right.
Old Sep 19, 2012 | 06:17 AM
winters97gt's Avatar
winters97gt
Cars don't race on dynos.
Sounds good OP! Make sure you have the fuel and a solid tune, and 125-150 shouldn't be an issue.
Old Sep 19, 2012 | 08:07 AM
ThumperNC24's Avatar
ThumperNC24
yeah but this thread is about dyno numbers....
I agree those numbers sound really really low. Torque looks nice though
Old Sep 19, 2012 | 11:00 AM
MX621's Avatar
MX621
Originally Posted by Silnus
Hand ported 243s
may have the culprit....
Old Sep 19, 2012 | 12:54 PM
Silnus's Avatar
Silnus
And using br7 plugs as well which will lower the hp. Keep in mind that the motor is on a nitrous tune so timing has been pulled.
Old Sep 19, 2012 | 01:29 PM
BryanV's Avatar
BryanV
Nice numbers, what was the bottle pressure on the runs?
Im thinking about spraying but im on the fence still
Old Nov 11, 2012 | 04:03 AM
The Highlander's Avatar
The Highlander
I got 604 from mine with 175 shot!
Stock bottom end.
Old Nov 11, 2012 | 09:35 AM
deadcafe's Avatar
deadcafe
Stock bottom end.
I am also on the fence with either a direct port N20system from nitrous direct or the trusty A&A Supercharger........ I like the Nitrous because of the cost effectiveness, I mean how often do you need 505rwhp driving to work? 7 grand is a tough pill to swallow for a SC....
When you have your car tuned for nitrous how is drivability off the bottle? how many good runs do you get on 1 bottle? what does your run consist of a 2nd 3rd 4th ? are you using a progressive controller? LOL thanks man.
Old Nov 14, 2012 | 04:31 PM
96juicedgt's Avatar
96juicedgt
Sounds good. Sharp car too! Very nice numbers.
Old Nov 14, 2012 | 06:14 PM
The Highlander
Well...
When I installed the 7L it was like being on the 150shot, but all the time... Although Nitrous has a lot better power band than N/A, its much more fun the 7L N/A than the 5.7 NOS with the same horsepower. With the 150shot I did 560rwhp.
Now.... I am pushing 100shot with the 7L for 660rwhp.
I am using the stock ECU and 15974NOS controller... I am not using it progressive.
If I had the choice... I would go supercharged... i wanted the nitrous because I could have the car for road racing and a little juice when a big race comes up, but for the types of racing we are gearing to, the charger would have been a better choice.
Driveability off the bottle is perfect. I don't see why there should be any issues off the bottle...
If you want to do a good nitrous system it will NOT come cheap.... Period... It's a tad unreliable and parts have a very short lifespan (nitrous parts/not the engine). I use the nano and honestly, even with the nano you can feel the car looses a tad of power each pass... its a lot better than without it, but it has its caveats. Nitrous is a high maintenance system....
The charger however... if you get the direct drive and don't have belt slippage issues... you will be fine and perfect...
Nitrous however is the best on the engine as 100hp on the flywheel is 100hp on the pistons.... unlike the charger or turbo where 100hp on the flywheel is like 150hp on the pistons... There is no parasitic loss... since it cools down the pistons they tend to live longer... obviously if tuned correctly and not just using the old stupid rule of 2 deg/50shot, which is completely RETARDED and stupid and that is a recipe for destruction.
Old Nov 16, 2012 | 07:37 PM
deadcafe's Avatar
deadcafe
[QUOTE=HighlanderX;1582333992]Well...
Understandable. A 7lt on the juice is a nasty machine...Thanks for the input and I con understant the bummer it must be when you start noticing you are low on the sauce. LOL so many pepople think you are cheating with it but so few really understand it or even how it works in the combustion chamber...
To C5Z on N20
