General repairs
Old Sep 19, 2012 | 04:40 PM
manuelw's Avatar
manuelw
Cruising
Default General repairs
Approximately what should I expect to pay Chev Dealer to replace Oil pan gasket and rear main seal gasket on 2002 Corvette?
Manuel
Old Sep 19, 2012 | 04:46 PM
oh1vette's Avatar
oh1vette
your left arm....
Old Sep 19, 2012 | 04:52 PM
f6john's Avatar
f6john
I suspect the left nut too. Wish I had a dollar figure but the thought is just to scary.
Old Sep 19, 2012 | 05:19 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
That rear main seal is going to be the issue. Wish I could tell you but I don't know
Old Sep 19, 2012 | 05:30 PM
maxx2200's Avatar
maxx2200
It's crazy expensive. Why do you think you need all of that replaced?
Old Sep 19, 2012 | 05:45 PM
manuelw's Avatar
manuelw
Cruising
Default General repair - gaskets!
Oh come on...give me a break! I'm only talking about replacing gaskets that seem to be leaking a little bit!
Old Sep 19, 2012 | 07:03 PM
bobeast's Avatar
bobeast
Doesn't the rear main seal require pulling the engine or driveline? I don't think its about the parts.
Old Sep 19, 2012 | 07:12 PM
andrec10's Avatar
andrec10
Try and find a good Corvette shop. I stealership does not have enough experience on these anymore.
Old Sep 19, 2012 | 07:14 PM
jrose7004's Avatar
jrose7004
I sure wouldn't take it to a dealer.
Old Sep 19, 2012 | 08:04 PM
oh1vette's Avatar
oh1vette
Theres a reason we call them STEALERships
Old Sep 19, 2012 | 08:23 PM
havocdog's Avatar
havocdog
You should expect to pay book time for repair muliplied by their door labor rate. Which will be stupid money. Where are you located?? Lots of good Vette shops to be reccomended by area.
Old Sep 19, 2012 | 08:37 PM
midlifetoy1's Avatar
midlifetoy1
Default General Repairs
Just had mine done...
Oil pan gasket: 4 - 5 hours labor, $600,ouch!
Having rear main seal replaced soon, was quoted 8-9 hours labor about $1200 - $1300
Old Sep 19, 2012 | 09:30 PM
BlackY2KCorvette's Avatar
BlackY2KCorvette
I have a vette shop near the house,he has a Dyno also,has a work shop in conjunction with a shop that is on here too from central Fl. (Jeremy).i was told to do the pan and crank seals......$2000 bucks!!!! its ALL labor......and while i was there he was doing one.........OMG! huge job. the exhaust.....out. the rear end/tranny......out. torque tube......out. the front K member....out. lower control arms bolt to that too. then its time to work on the pan.....bell housing....front cover.....$$$$$$$ and TIME.
my pan is wet and the driveway is a mess. who ever did the pan for $600 above this post........i wish i was closer!!..
Old Sep 19, 2012 | 09:39 PM
Cruncher's Avatar
Cruncher
Hmmmm...I was thinking both of them, not just one. I got charged $70 in labor to replace an A/C belt...I was with the tech and it took him less than 2 shakes of lamb's tail...what a rip off---but, it was according to "the book".
Old Sep 19, 2012 | 10:17 PM
m6 c5's Avatar
m6 c5
Are you sure your rear main is leaking? Its common for the oil pressure sending unit to leak down the back of the engine and to be mistaken for a rear main and or oil pan gasket leak.
Old Sep 19, 2012 | 10:25 PM
If you don't believe the numbers being thrown out here, why not just ask your local dealership or if available, a local Corvette shop, what they charge to do the repairs. I think you'll find it is a labor intensive job and as such, the cost is going to be up there.
Old Sep 20, 2012 | 09:07 AM
3boystoys's Avatar
3boystoys
Bend over BABY.
Old Sep 20, 2012 | 09:10 AM
maxx2200's Avatar
maxx2200
I'm living proof. It never hurts to get a second opinion.
Old Sep 20, 2012 | 09:54 AM
runner140*'s Avatar
runner140*
I can't find your location....to give you a repair shop in your area.
To General repairs
