The pop up projectors back?
Old Sep 22, 2012 | 12:01 AM
_Wayne_'s Avatar
_Wayne_
Default The pop up projectors back?
I was browsing the internet and visited the fleabay and happened to see several listings by the big sellers with the ACA (?) projectors that were pulled bc they were not DOT approved. must of got it figured out? anywasy im already dead set on making my own headlights based off of the breathless kit and the radio flyers, hopefully cheaper!
Old Sep 22, 2012 | 12:21 AM
racebum's Avatar
racebum
can't you just use plug and play hid bulbs? those aftermarket projectors sucked! they do for any car. all made in china and none reflect light correctly
i'm not sure if it's DOT that pulled them as some were sold direct from overseas
i would hope it's that people have decided to stop ricing out the corvettes
people make fun of these on honda-tech
that should say something
Old Sep 22, 2012 | 12:22 AM
_Wayne_'s Avatar
_Wayne_
I was just pointing out they are back, im going to develop my own fixed system
Old Sep 22, 2012 | 12:23 AM
dblerman's Avatar
dblerman
They're DOT approved... I believe the reason they weren't popping up on ebay for a while was the supply had just dried up, even the vendors were out of stock for a while. Same thing happened with the LED halo tail lights last year.
Old Sep 22, 2012 | 12:30 AM
racebum's Avatar
racebum
if you do, use oe lenses. the 94-97 acura integra used a projector lamp with some really good glass. they are also inexpensive. if you took those apart and adapted them to a c5 housing you could have a good system that used a 9005-9006 bulbs
what were your ideas?
Old Sep 22, 2012 | 12:33 AM
dblerman's Avatar
dblerman
HID + ACA projectors > HID + stock housing > halogens + stock housing
PLENTY of people on here are running projectors with HID and love them.
Oh, and ACAs are made in Taiwan.
Old Sep 22, 2012 | 12:41 AM
_Wayne_'s Avatar
_Wayne_
use the lenses from the breathless kit:
Find some good projectors 2 on each side like the radioflyer ones, make a simple mounting braket and fiber glass a shroud, so either make a product that is similar to these 1000+ lights for cheaper or make something that people can easily remake with stuff readily available online and at a local hardware store
Old Sep 22, 2012 | 12:43 AM
racebum's Avatar
racebum
if they do it's the bulb, not the lens.
i think that stuff is junk. guess to each their own
Old Sep 22, 2012 | 12:46 AM
racebum's Avatar
racebum
what are the lenses sourced from? something like that was kind of the idea i had in my head listening to your post. it's just that OE projector lenses are SO much better than that crap you see on ebay. side by side the light output is night and day.
http://www.ebay.com/itm/94-95-96-97-...275775&vxp=mtr
these actually pop apart and that projector lens you see is extremely good. wonder if you could mount that in your system rather than a china junker
typical used price on these is under 100 a pair. this auction is priced high
Old Sep 22, 2012 | 12:50 AM
_Wayne_'s Avatar
_Wayne_
Those look good, depending on the size it could possibly save a lot of time and money in mounting braket development, just need to find a reliable source for them
Old Sep 22, 2012 | 01:48 AM
dblerman's Avatar
dblerman
What's funny is that everyone on the Honda forums complain about the 3rd gen Integra projectors and retrofit mercedes E55 lenses into their HID setups.
Old Sep 22, 2012 | 10:49 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I've received many comments and compliments over the past two years regarding my HID projector ACA lights and "rice" was never one of them. Simply aim the projectors for the correct cut-off.
For those of you considering just installing HID bulbs in the stock halogen reflection designed housings and simply blasting light, please consider other drivers on the road.
Old Sep 22, 2012 | 01:42 PM
racebum's Avatar
racebum
LOL
you have a point there
people are never satisfied
Old Sep 22, 2012 | 01:47 PM
racebum's Avatar
racebum
check your local craigslist, people are always parting out the 94-01 integras. the 94-97 cars are the ones that have the lower cost headlights. 98+ are about 3x more
make sure they are oem units and not aftermarket china lights if you go this route.
may even be able to find some at a pick n pull
Old Sep 22, 2012 | 10:53 PM
Originally Posted by MSG C5
Those lights look very good on your car.
Old Sep 23, 2012 | 08:02 PM
phinfan's Avatar
phinfan
I'm not into many of the mods, but those look fantastic.
Would it be too much trouble to ask you where or how you went about that? Also what the approx cost was?
Old Sep 23, 2012 | 08:18 PM
Blown 346's Avatar
Blown 346
Get them off ebay, They are the same housing and wiring harness etc. The only thing you have to get after that is order a HID kit. I bought my ACA kit years ago when they first came out and that was $1000. You can get the exact same kit from Ebay and they are ACA brand for around $300. Then the HID kit up to $100 depending on who you buy thru.
To The pop up projectors back?
Old Sep 23, 2012 | 08:29 PM
MSG C5's Avatar
MSG C5
Originally Posted by phinfan
I'm not much many of the mods, but those look fantastic.
I purchased my lights through forum vendor JW Motoring. He provided the ACA housings, HID bulbs, ballasts and harnesses as well as my HID fog lights and could provide you current pricing as my system is over 2 years old.
The key for a successful HID upgrade is in the wiring and the bulbs/ballasts. In the end, the ACA housings are simply that, housings for the projector lenses.
Old Sep 23, 2012 | 10:00 PM
phinfan's Avatar
phinfan
How difficult is the installation, about how long/involved of a project is it?
Old Sep 23, 2012 | 10:25 PM
MSG C5's Avatar
MSG C5
It was pretty straightforward with the directions provided by JW Motoring. I also swapped out my corner lights/LEDs as well as my rear tail lights to the Halo LEDs to the entire project took we a weekend.
I took my time and everything worked correctly the first time. If you take this on, work one light at a time and then test afterwards in case you need to reverse engineer or correct any issues. If you install everything at once without testing along the way, you may not be able to figure out the problem if only one bulb doesn't fire.
Below is a link to my original thread detailing the project. Good luck!
http://forums.corvetteforum.com/c5-g...sion-pics.html
