Leaky Butt issue
Old Oct 3, 2012 | 12:23 AM
nickwfd92's Avatar
nickwfd92
Default Leaky Butt issue
Ok, I had a bad CV Boot, I replaced the axel along with a new axel seal. I am still leaking. I get an oil splatter all over the rear end around the tail lights, and approx. 20 dripps on the garage floor. any idea how to fix this issue?
Thanks for the help
Old Oct 3, 2012 | 10:02 AM
nickwfd92's Avatar
nickwfd92
Anyone have any ideas on how to fix this issue, I will be putting it in the air in a few hours. The car is a 00 coupe with M6, the seal is on the drivers side, looks to be leaking from the new seal area but will have a closer look soon.
Old Oct 3, 2012 | 10:19 AM
bumble-z's Avatar
bumble-z
Here you go.
Read all the posts.
Pay particular attention to #17 in regards to where the original poster purchased his aftermarket axle from & which ended up being the culprit of his leak at the axle seal.
Hope this helps.
http://forums.corvetteforum.com/c5-t...eaky-butt.html
Old Oct 3, 2012 | 11:13 AM
MrGary2011's Avatar
MrGary2011
I have been told that if the rear seal on the drivers side is not carefully installed, you will be reinstalling another one.
Old Oct 3, 2012 | 11:24 AM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Does this happen after spirited driving?
Old Oct 3, 2012 | 01:40 PM
I had a '00 MN6 car too and had the rear differential seal leak three times. On one of the occasions, the dealership replaced the cover plate as they said there was a TSB on them (something about them being too porus and prone to leakage). If the seal wasn't set in the cover just right, it may lead to leakage also.
Here's some files that talk about the rear differential seal leaks. I have a few other ones also, but they are too large to attach here on the forum. If you'd like a copy of them, just PM me your e-mail address.
To Leaky Butt issue
