Duplicolor RED brush on caliper paint is great and cheap
Cost about $15 and i ued it about 5 years ago when I replaced the front and rear pads. Removed calipers from brackets leaving the brake lines attached. Used a wire brush and brake cleaner (one can included with the Duplicolor kit) to completely remove grease and grime from calipers.
Used about 5 or 6 coats about 45 minutes apart to get good coverage.
Reassembled with new pads and touched up areas where I scuffed the calipers when putting them back and installing pads. Used white touch up paint on the CORVETTE letters on the front calipers. Still looks good 5 years later. Have enough paint left over to do one or two more sets of calipers.BIGHANK
Agreed,
Works great, lasts a long time and it was cheap
Reassembled with new pads and touched up areas where I scuffed the calipers when putting them back and installing pads. Used white touch up paint on the CORVETTE letters on the front calipers. Still looks good 5 years later. Have enough paint left over to do one or two more sets of calipers.BIGHAlNK
I used this kit too, it comes in many colors. I only used 3-4 coats. The paint contains ceramic and looks like it has been spray painted. Mine has lasted many years with no problems. I just scraped paint off of letters.
