New back up lights
Old Oct 6, 2012 | 09:42 AM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Default New back up lights
Yesterday I installed my reverse light housing and the 20 watt (I think) LEDs along with the the tag led lighting strip and vanity plate light, I am very impressed with the difference it made and the ease of the install I have always had a hard time seeing behind me at night when I'm backing my car into the garage and now its not an issue anymore, adding the led lighting strip for the tag and vanity plate led just seemed like the right thing to do to finish up the package. (Thanks Radioflyer)
Now I have to buy new LED tail lights.
Edit: I have moved the led light for the vanity plate since these pics were taken, I did not want it shining on the ground (just the plate)
Old Oct 6, 2012 | 10:37 AM
PhilsFRC's Avatar
PhilsFRC
I've got those backups also. REALLY great!
Old Oct 6, 2012 | 10:40 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
enjoy being able to see your driveway!
Old Oct 6, 2012 | 10:47 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Are these plate LED strips the same one you were designing earlier that plug into one of the OEM outlets? The ones pictured above seem to be lower.
Old Oct 6, 2012 | 11:47 AM
nvusgt's Avatar
nvusgt
Is it me or are the led strips facing outward? Shouldn't they be facing down and if not what exactly is the point of the strips on a license plate?
Old Oct 6, 2012 | 12:24 PM
skydiven4fun
Hey everyone, They are facing down and are mounted flush with the downward facing area above the tag, What everyone is seeing is the reflection on my tag bracket.
I guess I keep my car too clean
Old Oct 6, 2012 | 01:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice and bright
Old Oct 6, 2012 | 04:18 PM
TheRadioFlyer
Supporting Vendor
I thought that looked interesting.
Old Oct 6, 2012 | 05:46 PM
skydiven4fun
I'm gonna get some dirt on my car
(One day)
Old Oct 6, 2012 | 06:35 PM
PhysicsDude55's Avatar
PhysicsDude55
Which exact bulbs did you go with?
I've wanted a set, especially since I have tinted covers. I'm skeptical of most of the LED bulbs on the market, and was considering the HID's. Yours look good.
Light strip looks good too. looks better than sticking led bulbs into the stock housings.
Old Oct 6, 2012 | 07:32 PM
skydiven4fun
Pm Radioflyer for the details your asking about, he hooked me up with everything you asked about, and has been an awsome vendor to deal with, if you need anything else pm me and I'll be more than happy to help ok.
Old Oct 6, 2012 | 08:25 PM
TheRadioFlyer
Supporting Vendor
The LEDs are 20w elements (not bulbs) that emit 1000 Lumens over a 160 degree viewing angle. This makes them superior to most LED bulbs that simply sit in the housing. with radial-mounted LEDs that only take minor advantage of the reflector optics. HIDs certainly pump out a lot of light, but with they pull at least 35 watts while the factory bulbs pull 25w making it an electrical issue at the very least. A relay harness is required to successfully run HID bulbs in the reverse lights.
They are mounted on aluminum plates that are glued to the housing using OCI Butyl adhesive. This waterproof adhesive is the same type OEM use to seal headlight lenses to the housings.
You can purchase them here:
Radioflyer's 20w LED reverse lights
Old Oct 6, 2012 | 08:38 PM
maxx2200's Avatar
maxx2200
Looks great
Very nice car.
Old Oct 6, 2012 | 08:44 PM
Nice upgrade to the lighting - it looks great on you car.
Old Oct 6, 2012 | 10:11 PM
jrose7004's Avatar
jrose7004
Wow, looks really bright!
Old Oct 6, 2012 | 10:32 PM
Tron Z's Avatar
Tron Z
... just seemed like the right thing to do to finish up the package.
You don't really expect us to believe that you're finished, do you? You've got the fever, you can't fool me!
By the way, sweet ride! I've been hoping to bump into you in scenic downtown Montgomery, but I haven't spotted you yet.
Cheers!
D.W.
Old Oct 7, 2012 | 12:24 AM
skydiven4fun
Meeting in downtown Montgomery is definitly a timing issue, there ain't but 2 red lights, maybe 3 if you count hwy 105
Old Oct 7, 2012 | 01:03 AM
C5FORFUN2's Avatar
C5FORFUN2
Wanted these since I first saw them developed and finally decided to order them a few minutes ago.
To New back up lights
