Quick TCS question
Old Oct 9, 2012 | 09:42 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Quick TCS question
2001 Coupe. I gots the dreaded 1214U code! I have seen it occasionally come up and always went to history on next ign cycle and always cleared out no prob. Now, a day after installing my HID fog lights, it alarms any time the key is on and the code is persistently current. Still only 1214U. From reading the various threads I assume it's time to remove the module and get it rebuilt? Any other tricks to try first? Anything during the course of the foglight install that might have affected it? I appreciate the input!
TIA!
Old Oct 9, 2012 | 10:36 PM
CheezMoe's Avatar
CheezMoe
Default Move This to C5Tech?
Thats where I should have posted this. Mods can you help? Many Thanks!
Old Oct 10, 2012 | 01:14 AM
Jistari's Avatar
Jistari
Aside from the additional voltage drain from the new lights hitting an already marginal battery or exacerbating a ground issue.....1214 usually does mean the EBCM rebuild (but the good news is that with that it is usualy fixed and stays fixed....unlike some other codes).
Good luck
Old Oct 10, 2012 | 10:18 PM
CheezMoe's Avatar
CheezMoe
Good luck
Thanks! I have read quite a few threads now and I am pretty good with VOM and soldering Iron. Im gonna take it out this weekend and run thru some trouble shooting idea's, check the grounds and all. I have been keeping the tender on the battery for the most part and the lights have not been on when the car does not run. Charging system =14.1v. I'll see what I find!
To Quick TCS question
