Whistling noise?
Old Oct 12, 2012 | 07:40 PM
Bellie1's Avatar
Bellie1
Default Whistling noise?
I was on my way home from work today with the top down. I heard a whistling noise coming from the engine under slight acceleration. When I pushed down on the throttle it quit, I could hear the noise shifting from 1 gear through 4 gear. Any ideas?
Old Oct 12, 2012 | 08:23 PM
Cybermind's Avatar
Cybermind
Any mods such as cold air intake? First thing you should do is look for any obvious vacuum leaks. Any work done to the car recently?
Old Oct 12, 2012 | 08:29 PM
Bellie1's Avatar
Bellie1
I did install a cold air intake. No other work done to the engine.
Old Oct 13, 2012 | 12:07 AM
sonny557's Avatar
sonny557
Default Same
I have the same whistling noise when I get to 50+mph if i let off of the gas and give it a little more i hear a whistling under the hood, I can repeat it over and over, cant find any vaccuum hoses loose, I read somewhere a while back it has something to do with the MAS i think.
To Whistling noise?
