Powdercoat Stripping
Old Oct 19, 2012 | 06:58 PM
AVB's Avatar
AVB
Default Powdercoat Stripping
Anyone know of a good paint stripper that'll remove powdercoating? It's time to get my wheel centers back to a clear aluminum vs. black.
I've heard good things about Permatex 80646 gasket remover but it's no longer sold and nowhere to be found.
Old Oct 19, 2012 | 07:03 PM
sfc rick's Avatar
sfc rick
bead blast cabinet
Old Oct 19, 2012 | 07:06 PM
Baldfart's Avatar
Baldfart
Originally Posted by sfc rick
bead blast cabinet
Old Oct 19, 2012 | 07:21 PM
This might give you some good info:
File Type: doc
Old Dec 6, 2012 | 12:57 AM
AVB's Avatar
AVB
Thanks for all who responded....
Using heavy duty chemical paint strippers from OSH, I spent a week and successfully stripped two Fiske FM10 centers. Underneath the finish looked pretty good. I brought them to a wheel refinishing shop and got a quote to have them re-polished a slight machining (so they look like brand new FM10's) and re-cleared. The guy at the shop took a look at them and said, it's a good thing I didn't sand blast them or else he would have just turned me away. It turns out that blasting on a somewhat, webbed center like the FM10 would be a major pain and to get back that machined look would be waaay too much work and costly.
I told him I had two more centers which still hadn't been stripped and he said, bring them in and we'll take care of the stripping for no additional charge since we do it all the time!
Anyways... just glad I got lucky and am getting back a killer set of wheels w/13" wide rears!!
Old Dec 6, 2012 | 10:05 AM
c5chines's Avatar
c5chines
It's easy to remove powdercoat with a cutting torch.I know it sounds retarded,but just running the torch over the powdercoat with a bit of extra oxygen burns it right off without overheating the part.
Old Dec 6, 2012 | 08:43 PM
momo20's Avatar
momo20
mr gasket remover..works like a charm i know this only because i took powder coated red intercooler pipes for a wrx...sprayed mr gasket remover on them..and the powder coat was falling off in seconds..did a really good job too
To Powdercoat Stripping
