[Z06] Newbie looking for ADVICE
Old Oct 20, 2012 | 08:56 PM
DJR1971's Avatar
DJR1971
Default Newbie looking for ADVICE
Hello all. Just purchased my very first Corvette--a 2003 Z06 with 6,107 original miles from the original owner. She is black with black interior. This was a replacement for my 1989 IROC-Z that I sold after 22 years of ownership. The Z06 is bone stock and I am interested in any suggestions for modifications, both aesthetically and mechanical, as well as any maintenance concerns, storage concerns (I am in the Northeast), and any other advice. I plan to keep her for the next 25 years.
I already purchased a Deltran battery tender and I just ordered the GM front license plate frame to fill in the gap around the front plate required here in NY.
My most immediate need is a quality indoor car cover right now. Any suggestions???
I also plan to get Lloyds mats.
In addition to any car cover suggestions, I am most interested in cold air intakes, any other interior upgrades, fog/driving light suggestions, black-out lens suggestions, rear spoilers, etc.
Also, any suggestions for Corvette Club(s) to join?
THANKS!
Old Oct 20, 2012 | 09:13 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Do you have the maintenance records, if any, on the car? There are a couple of immediate maintenance items that I would be concerned about.
The first is the tires. If they are the original Goodyear F-1 tires (check date codes) they are now 10 years old. They have lost a huge amount of their elasticity and will be hard as a rock and probably starting to dry rot. I would replace them.
The second is the Dexcool engine coolant. GM suggests 5 year change cycle. If it has not been changed, that should be high on your priority list. A fresh engine oil change might not be a bad idea unless you have a record of a recent change.
For a cold air intake, I like the Calloway Honker a bunch. Great fit and finish, great filtration as opposed to some other systems, and has shown measurable dyno power increase.
Old Oct 20, 2012 | 09:18 PM
DJR1971's Avatar
DJR1971
Thanks. It has had 2 oil changes and a new battery. I am going to change all of the fluids--oil, coolant, diff, gear box, clutch, and brake fluid. Yes, original tires. Old, but no sign of dry rot. I will be storing the car soon here in the Northeast. Will be looking at tire replacement in Spring.
Old Oct 21, 2012 | 01:18 PM
skyavonee's Avatar
skyavonee
If the last 5 digits of your VIN are less than 07000, you might consider replacing your valve springs:
corvetteforum.com/c5-z06-discussion/build-date-vin-analysis-of-ls6-valve-spring-failures.html
Also do a forum search for "steering column lock" to find a cheap and easy maintenance task that might save you from a big headache later on down the road.
Old Oct 21, 2012 | 01:25 PM
Paul 75 L82's Avatar
Paul 75 L82
Buy new tires, those are dangerous! Then just read threads on the forum, there is so much info here. Welcome aboard.
Old Oct 21, 2012 | 08:45 PM
DJR1971's Avatar
DJR1971
My is a late 2003. Vin is in the 24,000's. Also, it had a recall done for the column lock issue. Thanks!
To Newbie looking for ADVICE
