[Z06] 2003 Z06 Known Problems
Popular Reply
There are "CONCERNS" for C5s in the 2001-2004 era. One such concern is the ECBM issue. This is not a common problem, just a known concern. I had a 2003 and a 2004 and did not have any issue whatsoever with either car. Any year, any car can have it's own problem(s). I try to ascertain how the car was used or abused. Then I take a hard look at maintenance. There are cars that are cared for, and ones that suffer neglect.
There are issues like the column lock feature that haunts all the C5s, and then you read an occasional leaking real axle issue. I would say if you can lay hands on the car, and look at things like raising the hood, and look in at the screen where the wipers lay. Is it clean or is there debris there?
How about looking at the door hinges. Are they clean or covered in dirt and grease?
I'm a detail nut so I clean out the troughs where water collects. I even pull the wheels off and clean and polish the inside barrels of the wheels where all the brake dust collects.
These are things I examine and try to find a car owned by an **** retentive detail nut like myself.
Then look at service records and see if you are truly buying a Corvette lovers car or just another driver. Good luck on your decision.
That said, we are getting cool air now at our latitude. My car was just RDF (real damn fast) today. I can barely use first gear in this weather, the car rips through it subsecond. I start off in second, and I'm doing 65 in a blink. I have a Dewitts radiator, and when I got home to my driveway, the car was running at 153 degrees. For the money, you can't buy a more thrilling car to drive. I got the longtube headers and a short shifter. It's a constant passion fruit of easy to do upgrades.
The car has 96k on it. --Thats a lot of miles
Rip in the drivers seat. --New seats best repair
Roof is starting to fade. --the sun does, this not a wash mit
19,600.00
I am sure it has been well maintained and is priced high because everyone talks people down a couple grand. I would pass and find a lower mile car like you did as well.
Valve Spring Failure
Harmonic Balancer Wobble (No GM fix for C5 right through 2013's)
Fuel Leak/cracked crossover on late C5
EBCM
etc
etc
Your reading assignment...
http://forums.corvetteforum.com/show....php?t=1249213
U will be tested when U buy one
