If you can't get to it you can also order one from the National Corvette Museum online. You can also order the window sticker. They will laminate for a nominal charge as well.
From: Wylie TX --> Less is More, except under the hood !
That's what I did.... I'm not removing my front bumper...
I agree that the placard in the glove box tells you the RPO codes. But knowing what they mean is another animal. When I got my build sheet the RPO codes were listed and indicated exactly what they meant (colors, options) as they applied to my particular vette.
and it is a good deal. I had to have my front fascia taken off not long after I got the car and went ahead and pulled out my build sheet then. Got it framed on the garage wall now.
Pulled my bumper off to paint and got my build sheet out at that time. Pic needs to be rotated but you can see where it is in relation to the fog light.
I just wanted the original. it was starting to show some aging after 12 years in there.
