B&M or Hurst?
Old Oct 23, 2012 | 12:39 AM
almost had 1's Avatar
almost had 1
Default B&M or Hurst?
Buying a short shifter, is a B&M worth the few dollars more than the hurst, or are they both the same?
Old Oct 23, 2012 | 02:35 AM
Camaro_94's Avatar
Camaro_94
Im not happy with my hurst shifter.
the setskrew came loose one night and wouldnt let me shift into 1-3-5-R gears. Not a fan after that.
Old Oct 23, 2012 | 07:16 AM
hp_therapy's Avatar
hp_therapy
I had a Hurst in my '01 and had no issues with it. For my '04 I went with a TPS Motorsports Attack Short Shift, so far so good.
Old Oct 23, 2012 | 08:05 AM
Ron C!'s Avatar
Ron C!
I have Rippers in both of my cars, along with the anti-venom mod. For me, it is the best of all worlds.
Old Oct 23, 2012 | 08:25 AM
k0ts's Avatar
k0ts
Hurst, no problems!
Old Oct 23, 2012 | 08:41 AM
DarkBlueC5's Avatar
DarkBlueC5
Not to step outside your original question, but have you considered the MGW? Do some search on this forum, you'll find that it comes highly recommended. I installed the MGW short shifter this spring and it is awesome. Quality of materials is top notch. Good luck with whatever you choose!
Old Oct 23, 2012 | 08:56 AM
johnsos30's Avatar
johnsos30
No issues with my Hurst
Old Oct 23, 2012 | 12:25 PM
B747VET's Avatar
B747VET
Very happy with B&M Ripper and Anti-Venom mod. But, I haven't had the other two.
Until the day that someone who's had both or all three writes a very, very detailed review, all your going to get is very limited input, including mine, that really isn't of much use in the decision making process.
Good luck.
Old Oct 23, 2012 | 12:52 PM
onspeed's Avatar
onspeed
I had a B&M Precision Sport (2pc shaft to reduce vibrations) and it was pretty good. Recently upgraded to an MGW which is also pretty good, but not worth the $100+ price difference over the B&M, IMO.
Old Oct 23, 2012 | 12:58 PM
tentuna's Avatar
tentuna
I put in the B&M Sports shifter, very happy with it, have not done the Antivenom mod., would like to know a little more about it before I do it.
Old Oct 23, 2012 | 03:27 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i experimented with a lot of different short shifters before finally deciding on an MGW. i actually bought and installed a B&M, hurst, and several others before the MGW and i was more than happy to sell off each and every one of them when i decided on the MGW. in my mind, there was no comparison. obviously since it is just an opinion, you will get many conflicting opinions., but for what it's worth and assuming you don't want to consider anything other than a B&M and hurst, my choice would definitely be the B&M. again my opinion only, but the one shifter i disliked the most was the hurst. i still have the 04 ce convertible and it still has the MGW shifter in it.
Old Oct 23, 2012 | 05:39 PM
johnson-rod's Avatar
johnson-rod
Hurst shifters and Corvettes go together like peas and carrots.
Old Oct 23, 2012 | 10:47 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
B&M for me with the anti venom mod... (one washer) No experience with a Hurst.
Old Oct 24, 2012 | 04:24 AM
pugads650's Avatar
pugads650
i absolutley hate my hurst shifter its super notchy and its hard to get it back in 1st after im getting out of reverse. but then again i bought it second hand so i probably need to mess with springs
Old Oct 24, 2012 | 07:35 AM
Daddyrama31's Avatar
Daddyrama31
I like my Hurst
Old Oct 24, 2012 | 09:35 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I had the B&M in my deceased C5 and here it what I really liked about it. When I ran it hard at the Texas Mile I never missed 3rd or 5th and those gears are easy to miss with the up throw as I have seen many other at the Mile with other shifters, oh I went a mere 190+ MPH at the Mile
To B&M or Hurst?
