Spark plug and wire change
Old Oct 30, 2012 | 09:11 AM
Kehraus's Avatar
Kehraus
Default Spark plug and wire change
Well, I spent a little over three hours doing the plug and
wire change. I decided to go with AC Delco Iridium plugs
and GMPP 8mm wires. The wires came from forum vendor,
GMPartshouse, and the plugs came from AutoZone and
have a $2 rebate per plug till the end of the year.
I checked the gap on the plugs, and they all needed to
have the gap adjusted. They weren't even all the same.
I can see where people say it takes an hour, but I really
struggled with the wire boots on the plugs. I tried the
wiggle twist and pull method to no avail.
Ended up using channel-locks to get most of them off.
It was hard to get them where they needed to be
and then 'grab' the boot.
Plugs came out ok, I ended up removing the rubber AIR
hose by the check valve to gain some clearance but it
was still really tight access.
Went for a test drive afterwards and of course the
throttle response was improved at any RPM, and a push
of the throttle to WOT from any rpm was improved.
Good to go for another 100,000! Wa-Hoo!!
Old Oct 30, 2012 | 09:15 AM
black match box's Avatar
black match box
good job done.
Old Oct 30, 2012 | 10:01 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
In any price range or quality you want, you can get a boot puller.
Amazing what having the right tool for the job is worth.
http://shop.advanceautoparts.com/web...hedFrom=header
Ps... Good for another 30,000 miles if you prefer not driving 70,000 with the plugs not lighting things up right. By virtue of the fact that you noticed a big difference, should be telling you it was way too long since they were changed. Wires more so than plugs imho.
Old Oct 30, 2012 | 10:05 AM
Congrats on a job well done.
Old Oct 30, 2012 | 10:50 AM
runner140*'s Avatar
runner140*
Congrats....and for the record, I can't do it in an hour either.
Old Oct 30, 2012 | 10:56 AM
andrec10's Avatar
andrec10
I feel better seeing it took someone 3 hours. Took me about 2 this summer and you had people saying they could do it in 10 minutes....Yeah ok.
Old Oct 30, 2012 | 11:20 AM
knewblewkorvette's Avatar
knewblewkorvette
I should probably do this on my 02. Car has only 24,000 miles on her but she is 10 years old....damn, 10 years old already
Old Oct 30, 2012 | 11:32 AM
BlackY2KCorvette's Avatar
BlackY2KCorvette
me too... driver side is a ______!
Old Oct 30, 2012 | 11:58 AM
VETJAZZ's Avatar
VETJAZZ
My 03 has 28k. I should probably consider this as well. She'll be 10 on 11/4!
Old Oct 30, 2012 | 12:02 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I have the wires and plugs and over 100K......just time and good weather ...... and motivation needed to git-r-dun.
Old Oct 30, 2012 | 12:03 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Originally Posted by vetjazz
my 03 has 28k. I should probably consider this as well. She'll be 10 on 11/4!
drive it!! :d :d
Old Oct 30, 2012 | 12:06 PM
chris04gto's Avatar
chris04gto
Took me 2 hours and I had the wire pulling tool. Of course I'm slow.
Old Oct 30, 2012 | 12:19 PM
Blown 346's Avatar
Blown 346
Agreed dont wait 100,000 miles. Plan to change them every 30,000, and check a few every 3rd oil change.
Old Oct 30, 2012 | 02:24 PM
Kehraus's Avatar
Kehraus
Do they require the use of those metal shrouds? I can't see
those pullers being more effective than the channel-locks,
especially since I was replacing the wires and could basically
ruin them during removal if necessary. They hang enough off
the end of the plug that I didn't feel that the actual plug
would get damaged.
I also didn't re-use those shrouds as there seemed to be
enough room around the boots.
Old Oct 30, 2012 | 03:38 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Kehraus
AC Delco Iridium plugs...
I really struggled with the wire boots on the plugs.
and that's a good reason to never reuse plug wires. You're likely to damage a few just trying to take them off.
I lengthened my wires
ref: http://forums.corvetteforum.com/c5-t...lute-zero.html
To Spark plug and wire change
