My 03 Z06 Has LG pros/ catted X pipe, Corsa extreem exhaust, blackwing CAI, comp cams spring upgrade and Harland sharp roller rockers, and it feels really fast, like 400RWHP. (I know but keep reading)
So I got to wondering if the HS's make any difference at all and saw an artical in Car Craft mag, of course this was not on a LS engine but it was good to see.
"First we ran the motor with a set of stock 1.5:1 stamped rockers with pivot-ball fulcrums, and averaged 389.9 hp and 407 lb-ft of torque at 6,000 rpm. With the baseline laid down, we moved on to a set of Comp Cams 1.5:1 roller rockers. At the same 6,000-rpm peak, we made 401.1 hp and 412.9 lb-ft of torque, a gain of 11.2 hp and 5.9 lb-ft of torque.
Stamped steel rocker arms are mass produced and are typically not precise. Some of the hp gain can be attributed to the more accurate HS. The Impact on a LS would not be as dramatic.
The full roller rockers might make that much difference on an LS motor with a high lift cam where the rocker tip is not getting a good wipe pattern on the valve stem. The LS engines have a roller pivot but not tip.
The first gen motors were all stamped with no roller pivot so frictional losses were much higher and 10+hp gain was common going to full roller.
With stock cam on an LS motor going to a full roller rocker with same as stock ratio (1.7), you'd be lucky to gain 1hp.
You dont think that less friction would create more HP/TQ?
On an LS motor, roller rockers would only be reducing the friction between the top of the valve step and rocker arm. In the test you mentioned in post #1, they replaced none needle bearing rocker arms (ie, "stamped rockers with pivot-ball fulcrums") with the rollers, so the main friction reduction was at the main pivot point of the rocker arm, not at the tip of the rocker arm.
