Side Mirror Adhesive
Old Nov 2, 2012 | 10:25 PM
RedeyeJK's Avatar
RedeyeJK
Default Side Mirror Adhesive
Quick question. I recently had the glass portion of my side mirror pop off. Luckily nothing broke because the two wires that hook to the heater bars stayed attached and I was able to catch it before anything really bad happened.
I need to glue/stick/adhere the glass back to the plastic backing of the side mirror. Any recommendations on what to use? I did a search on the forum and saw something about using a high temp, 100% silicone adhesive. Any thoughts on a name brand? Any tips on how to get this back on without 1) breaking the mirror and 2) getting it attached enough that it won't fall off the next time I drive down a the cobblestone streets in Richmond?
Thanks in advance!
Old Nov 2, 2012 | 10:33 PM
You might want to just take it to a glass shop and have them put the glass back on - shouldn't cost much and they would have the right glue.
Old Nov 3, 2012 | 07:07 AM
FLZapped's Avatar
FLZapped
Because that mirror has some electrical circuits, you'd probably want to use Dow Corning's low VOC silicon adhesive that is safe for electronics. I no longer work where we used it, so I can't tell you the number, sorry.
-Bruce
To Side Mirror Adhesive
