Tires!
Old Nov 6, 2012 | 11:42 PM
mydreamc5's Avatar
mydreamc5
Default Tires!
I have a 2002 coupe Z51 with stock rims. Would a tire size 255/45ZR/17 fit my front tires? I found some for a good price, just want to know if they will fit. The brand is goodyear eagle f1. Thanks in advance!
Old Nov 7, 2012 | 12:31 AM
napacruzerc5's Avatar
napacruzerc5
You mean would it fit your front rims. Probably but I wouldn't. As much as I like the design looks of the GY tire there are better and cheaper tires out there. I prefer the Kumho MXs in stock sizes.
Old Nov 7, 2012 | 08:21 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Yes they will fit. This is the size tire that the base '93 to '96 corvettes had with the same size (17" x 8.5") front wheels.
They will be slightly taller than your stock tires though. I suspect you will still have enough difference in front to rear height (0.6") that it will still not cause AH/TC issues.
The stock sizes are
Front 245/45/17 25.7" O/D
Rear: 275/40/18 26.7" O/D
Front 255/45/17 26.1" O/D
Rear 285/40/18 27" O/D
If you are thinking about rear tires too, the 285/40/18 makes a good match to the 255/45/17 front tires and is a little wider than stock. This combination keeps the front to rear diameter difference close to stock to avoid AH/TC problems and the combination will fit either the base wheel sizes or the Z06 wheel sizes. I have this combination on Z06 wheels on my '99 and like it.
Old Nov 7, 2012 | 10:58 AM
mydreamc5's Avatar
mydreamc5
Thanks for the replys! My front tires are shot and the back ones are still good. I was looking for replacments for the front and found some for cheap! Thanks again!
To Tires!
