Tranny ???'s,help
Old Nov 7, 2012 | 01:57 AM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Default Tranny ???'s,help
Al little forum help please, pulled into garage and turned car off. 30min's later went out to wash,started it up went to shift and nothing. Shifter moves back and forth with it catching nothing. Probably cable came lose or snapped,but the other problem is the car is in the garage and can't really jack it up. Can I remove console and reach the shift lever on the tranny from inside the car? Sorry,it's a automatic before anyone ask. Won't get back on here until late Wednesday night, thanks. L8R ZFLASH
Old Nov 7, 2012 | 05:52 AM
damilleniumboy's Avatar
damilleniumboy
The shift linkage is on the driver's side, rear wheel, just above the ttansmission craddle. There is a white plastic piece going from the shifter cable end to the metal shift link/arm in the transmission probably broke or came loose. No you can't shift it by removing the console; it can only be reached from under the back side of the car at the transmission.
Old Nov 7, 2012 | 07:17 AM
Good luck with this problem. Hope you can get it in a position where you can get it fixed. Let us know how you end up getting it out of the garage.
Old Nov 7, 2012 | 10:22 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Can you get a low-profile jack in under the rear axle? If so, you should be able to lift the car, remove the rear wheels to take pressure off the suspension, and have enough room to perform the suggested repair.
Old Nov 8, 2012 | 12:41 AM
ZFLASH's Avatar
ZFLASH
Thanks guys,I knew ya'll would come through. AAA is sending wrecker out in the A.M. to take it to Corvettes of Houston. I'm thinking of jacking it up and trying to use wheel dollies to get it out of the garage,we'll figure something out.
Old Nov 8, 2012 | 08:49 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Damm ! Good luck with the repair !
Toque
Old Nov 8, 2012 | 09:55 AM
damilleniumboy
You can move the car if you manually move the shift link/arm. You can get to it from the drivers side rear right in front of the transmission craddle. Just make sure you either put blocks on the tires or have someone press the brake pedal for your safety.
Old Nov 8, 2012 | 02:31 PM
bucwheat's Avatar
bucwheat
Good luck.
Old Nov 8, 2012 | 03:14 PM
ZFLASH's Avatar
ZFLASH
Thanks,that is what we did. It's already fixed and I'm back home with it. Corvettes of Houston took it right in and replaced the cable,in and out in a hour in a half. Thanks guys,L8R ZFLASH
To Tranny ???'s,help
