LED tail lights with Hyperflash harness
Old Nov 8, 2012 | 12:42 PM
AngryTurtle's Avatar
AngryTurtle
Default LED tail lights with Hyperflash harness
If i install a hyper flash harness can I remove the load resistor from the back of tail lights then just solder the 2 wires together?
Old Nov 8, 2012 | 05:02 PM
PhilsFRC's Avatar
PhilsFRC
Why would you want to that? When I first installed my LED tails with the integral resistors, they would occasionally hyper-flash. Could never figure out why since it was intermittent. Added the hyperflash harness and it never did it again. Added LED fronts with the same results. I would say leave them the way they are.
Old Nov 8, 2012 | 10:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
no it wont work.
http://forums.corvetteforum.com/c5-g...side-pics.html
Old Nov 8, 2012 | 11:57 PM
Good information from that older post.
Old Nov 9, 2012 | 12:20 AM
_zebra's Avatar
_zebra
after i installed my LED tails, i only got hyperflash if the engine wasn't running or if the signal had been on for a while. when i added LED turn signals up front, it hyperflashed all the time. i added the harness under the dash & everything blinks at the normal rate now.
Old Nov 9, 2012 | 01:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
^ that's not what we're talking about.
Old Nov 9, 2012 | 01:13 AM
_zebra's Avatar
_zebra
what i meant was that i didn't have to do any soldering work in the back - just plugged in the flasher harness & it fixed the problem
Old Nov 9, 2012 | 11:09 AM
AngryTurtle
Originally Posted by jdmvette
Thank you for doing exactly what I was planning to. Even though the end result seems illogical.
To LED tail lights with Hyperflash harness
