Bought a used(55k mi) C5 conv. last Dec. Had a set of GYeagles on. One blew out on the interstate. Got new a set of Nitto55d's. Like them. Problem is one keeps loosing air when driving. Sitting in garage OK so far. Had it checked completely. Can't find an answer. Must be crack in wheel ????? Thanks for any help..
bad valve stem, or possibly just a lil corrosion on the wheel bead area. Have it dismounted at a real tire shop. Theyll have wire brushes they can run around the bead and theyll have a sealant for it as well and it should fix you right up
